29633 Discussions
Error in reading multiple lines text data
Laoya__Tang
Dear all,
I have the following code:
    program readtest
    implicit none
    ! Variables
    integer::n
    real*8,allocatable::th(:)
    open(1,file='test.dat')
    read(1,*)n
    allocate(th(n))
    read(1,*,err=1,end=1)th
    continue
    ! Body of readtest
    !print *, 'Hello World'
1   &
    close(1)
    deallocate(th)
    stop
    end program readtest
The data in 'test.dat' are as follows:
122
0.02,0.06,0.10,0.14,0.18,0.22,0.26,0.30,0.34,0.38,0.42,0.46,0.50,0.54,0.58,
0.62,0.66,0.70,0.74,0.78,0.82,0.86,0.90,0.94,0.98,1.02,1.06,1.10,1.14,1.18,
1.26,1.34,1.42,1.50,1.58,1.66,1.74,1.82,1.90,2.00,2.10,2.20,2.30,2.40,2.50,
2.60,2.70,2.80,2.90,3.00,3.10,3.20,3.30,3.40,3.50,3.60,3.70,3.80,3.90,4.00,
4.20,4.40,4.60,4.80,5.00,5.20,5.40,5.60,5.80,6.00,6.20,6.40,6.60,6.80.7.00,
7.20,7.40,7.60,7.80,8.00,8.20,8.40,8.60,8.80,9.00,9.20,9.40,9.60,9.80.10.0,
10.2,10.4,10.6,10.8,11.0,11.2,11.4,11.6,11.8,12.0,12.2,12.4,12.6,12.8.13.0,
14.0,15.0,16.0,17.0,18.0,19.0,20.0,21.0,22.0,23.0,24.0,25.0,26.0,27.0,28.0,
29.0,30.0
Now the problem is that when running this program the code jump to 1 after read first 73 data, however, there are totally 122 data. Could anyone tell me how to modify the code to let the code read all these data? The environment I tested the program is: Windows 7 64bit + VS2010 + IVF13.1.3.198.
Zhanghong Tang
John_Campbell
New Contributor II
Check your data, as you have errors on the end of lines 6,7 and 8. "6.80.7.00" should be "6.80,7.00" etc.
If you import your data into excel, you will see the errors.
It would be good if there was an option something like : READ (unit=11,fmt=*,count=n) array(*). Returning count would give the flexibility to read as many numbers as available in a single record.
Laoya__Tang
Hi John,
Thank you very much for your so quick reply. I got it, thanks.
