29657 Discussions
Error :ld: final link failed: Nonrepresentable section on outputmake: *** [all] Error 1
Syed_Ahsan_Ali
Dear All,
I am getting the following error while compilation of an application. Please help me get out of this. Thanking you in advance
ld: ../../bin/gme2hrm: hidden symbol `__intel_cpu_indicator_init' in /opt/intel/Compiler/11.1/073/lib/intel64/libirc.a(cpu_disp.o) is referenced by DSO
regards
Ahsan
mecej4
We could try, if we knew how you got into "this".
How were the objects compiled, and how was the linking attempted? In particular, was ld invoked directly? Did you use a makefile? --- etc.
TimP
Among the ways in which you might produce this situation are by linking against multiple incompatible versions of ifort libraries, or by creating a shared object which is partially linked internally against the compiler static libraries.
Syed_Ahsan_Ali
Thanku for replying I am using following make file to link
# Following definition is required. You may adapt it to your needs.
STDROOT=${PWD}
# Following definitions are required. Do not change them.
SRCDIR=$(STDROOT)
OBJDIR=$(STDROOT)
# Define the name of the library
NAME=gme2hrm
# Load the binary names
include FileNames
# Load compiler options
include Options
# Load the list of object files
include Objfiles
# Define the calls for compiling
FTN=$(FTNCALL) -c $(FTNLST) $(FTNDEB) $(FTNANSI)
CC=$(CCALL) -c $(CC_LST) $(CC_DEB) $(CC_ANSI)
# Load the search path names for object libraries
# and the additional object libraries for linking
include LinkLibs
# Define include files for external usage
PUBFILES=
# Define plane object files for external usage
PUBOBFIL=
# Do all the compiling and linking stuff
# /SX/usr/bin/sxar For NEX SX
all: $(OBJFILES) $(PUBOBFIL)
rm -f $(NEWLIB)
ar qv $(NEWLIB) $(OBJFILES)
for MAIN in $(BINARIES) ; do \
if [ $${MAIN} != 'IGNORE' ] ; then \
$(FTNCALL) -o $${MAIN} $(OBJFILES) $(EXTOBJ) $(LINKOPTS) $(LIBPATHS) $(LIBS) 2>&1 >> $${MAIN}.map; \
fi \
done
# Cleanup
clean:
rm -f $(OBJDIR)/*.o $(OBJDIR)/*.l* $(OBJDIR)/*.L* $(OBJDIR)/*.kmo $(OBJDIR)/*.mod
# Load the dependencies list
include ODependencies
