29650 Discussions
Error message about multiple PRIVATE statements not being allowed
Arjen_Markus
I am experimenting with a generic programming technique - via rename clauses, see the code below - and I get an error message about multiple PRIVATE statements being used. I do not quite understand why because the two statements are in separate modules:
module quaternion_def_basic
    implicit none
    type quaternion
        !type(complex) :: c(2)
        complex :: c(2)
    end type quaternion
end module quaternion_def_basic
    use quaternion_def_basic, only: T => quaternion
module octonion_def
    use quaternion_def, T2 => T
    implicit none
    private :: T2
    type T
        type(T2) :: c(2)
    end type T
end module octonion_def
module sedenion_def
    use octonion_def, T2 => T
    implicit none
    private :: T2
    type T
        type(T2) :: c(2)
    end type T
end module sedenion_def
If I comment out the PRIVATE statement in the sedenion_def module, the code is accepted. Can anyone point out whether this is a genuine programming error or something that is wrong in the compiler. FYI: gfortran does accept the code.
I am using Intel Fortran 2015 for this.
Kevin_D_Intel
This appears to be a defect so I reported it to Development. It is also reproducible with PSXE 2016 (16.0 compiler). The clash appears to only involve the symbol. Tinkering with the test case to use a different name inside sedenion_def, I find that T2 from octonion_def is not accessible.
(Internal tracking id: DPD200376628)
andrew_4619
error #6265: This symbol has multiple PRIVATE statement/attribute declarations which is not allowed.   [T2]
It look OK to me. If in sedenion_def your change t2 to t3 the problem goes away suggesting there is some namespace pollution from octonion_def in sedenion_def.
On another note the cascade of re-definitions using the USE rename feature I found really confusing. I had to read the code three times before I understood it. Do you really want to do such a thing?
Arjen_Markus
Kevin, thanks for taking care of this.
app4619, I use the renaming bit to get a kind of templates within the current Fortran standard. If I were to use this in actual code, then I would chose more descriptive names, but this was a small illustration only :). It requires some careful thinking, I agree, but it seems a useful tool to set up generic code.
