29350 Discussions
Error message from the linker: relocation R_X86_64_32 against 'a local symbol'
Arjen_Markus
I am trying to compile and link a program on a 64-bits Linux machine, using Intel Fortran 11.
On at least one object file I get an error message from the linker that: relocation R_X86_64_32 against 'a local symbol' can not be used when making a shared object; recompile with -fPIC.
All source files have been compiled with -fPIC, so the message is at the very least misleading.
What sort of things in my source code could cause this message? Or is it a compiler bug?
(I know one cause for this type of message in C code - has to do with conflicting visibilities,
but as far as I can tell, the Fortran code does not contain anything in that direction)
Arjen
mecej4
This error is usually encountered when GNU Configure and Make are used with some incorrect flags, as described in this helpful article:
HOWTO fix -fPIC errors
Arjen_Markus
Hi mecej4,
it may actually something as simple as leaving out the -fPIC flag - I had judged from all the occurrences
of -fPIC in the output from "make" that it was used for all compile steps, but it definitely was not.
So now I am trying with an explicit -fPIC flag ... Thanks for the advice so far.
Arjen
mecej4
You may need to manually purge old objects that were compiled without -fPIC, since Make cannot distinguish between objects compiled with -fPIC and those compiled without -fPIC. Or, you could or clean everything and restart building.
Arjen_Markus
Adding -fPIC to all compile steps certainly helped. I ran into a system library that was not available
as a shared library, but it seems to be solving the problem all right.
Arjen
