29640 Discussions
Error passing text-string in a subroutine call
reidar
New User
When compiling the code below I get the message:
Error 1  Error: If the actual argument is scalar, the corresponding dummy argument shall be scalar unless the actual argument is an element of an array that is not an assumed-shape or pointer array, or a substring of such an element.   [TEXT] C:\CALC\veivaks\Veivaks2_IVF\Veivaks2_IVF\Example_Source1.F90 14
Error 2  Error: If the actual argument is scalar, the corresponding dummy argument shall be scalar unless the actual argument is an element of an array that is not an assumed-shape or pointer array, or a substring of such an element.   [TEXT] C:\CALC\veivaks\Veivaks2_IVF\Veivaks2_IVF\Example_Source1.F90 17
This sibroutine and call has been used for VAX/VMS, MS Powerstation and with CVF without problems, but with IVF it do not work. What's wrong:
The example code is attached
GVautier
New Contributor III
Hello
Old compilers doesn't detect such usage : treating as character*1 array a character*n argument.
Replace
CHARACTER*1 TEXT(50),IEND,TEX(50)
by
CHARACTER*(*) TEXT
CHARACTER*1 IEND,TEX(LEN(TEXT))
and
TEXT(I)
by
TEXT(I:I)
I think it will works
GVautier
New Contributor III
Hello
Replace
by
CHARACTER*(*) TEXT
and
TEXT(I)
by
TEXT(I:I)
