Error using -parallel parameter
herrera__jorge
Hello.
I'm actually install Ubuntu 18.04 with the intel parallel 2019 update 3. When I compiled my code just with the -c option, it works fine but when i'm trying to do the same but now with the -parallel option i get those messages:
Console2.o: In function `MAIN__':
Console2.f90:(.text+0x5c): undefined reference to `__kmpc_begin'
Console2.f90:(.text+0x1f8): undefined reference to `__kmpc_ok_to_fork'
Console2.f90:(.text+0x21d): undefined reference to `__kmpc_fork_call'
Console2.f90:(.text+0x5e6): undefined reference to `__kmpc_ok_to_fork'
Console2.f90:(.text+0x6ba): undefined reference to `__kmpc_fork_call'
Console2.f90:(.text+0x93d): undefined reference to `__kmpc_ok_to_fork'
Console2.f90:(.text+0xa0a): undefined reference to `__kmpc_fork_call'
Console2.f90:(.text+0x1810): undefined reference to `__kmpc_end'
Console2.f90:(.text+0x18d1): undefined reference to `__kmpc_for_static_init_4'
Console2.f90:(.text+0x22f4): undefined reference to `__kmpc_for_static_fini'
Console2.f90:(.text+0x23ba): undefined reference to `__kmpc_for_static_init_8'
Console2.f90:(.text+0x25d1): undefined reference to `__kmpc_for_static_fini'
Console2.f90:(.text+0x2692): undefined reference to `__kmpc_for_static_init_4'
Console2.f90:(.text+0x2969): undefined reference to `__kmpc_for_static_fini'
To compile I'm doing this:
./ifort Console2.f90 -nologo -O3 -parallel -qopt-matmul -real-size 64 -c Console2.f90
And the error above appears when i'm trying to change the object code to an executable.
Do any have a idea?
Juergen_R_R
Valued Contributor II
The third step is the linking step. As I said use the -parallel flag there, too:
3.  ifort -parallel Console2.o
Juergen_R_R
That has been discussed in a different context, I think you need to add -parallel also to your link command, cf.
https://software.intel.com/en-us/forums/intel-c-compiler/topic/289668
herrera__jorge
Could you tell me how please because if I'm doing it right, that's not the solution.
Thanks !
Juergen_R_R
It would be more beneficial if you showed us the code and your compile and link commands.
herrera__jorge
These are the steps that I'm using
1.- source /home/lalo/intel/parallel_studio_xe_2019.3.062/compilers_and_libraries_2019/linux/bin/compilervars.sh ia32
2.- ifort Console2.f90 -nologo -O3 -parallel -qopt-matmul -real-size 64 -c Console2.f90
3.- ifort Consolo2.o
In the third step is when I received the errors
But if i did the same without the parallel option it works !
2.- ifort Console2.f90 -nologo -O3 -qopt-matmul -real-size 64 -c Console2.f90
The code that I'm using i test it in Windows with the same version of intel parallels with Visual Studio and is working, but i'm doing a research and i need to do it in linux
Juergen_R_R
herrera__jorge
Hello !
I wasn't understanding you ! Now it is working !!
I'm so thankful !
