Error with a function !
Andrew_F_1
Every time I try to execute this program, it says : error #6236: A specification statement cannot appear in the executable section. Does anybody has any idea about the reason ? Thanks
program FP
implicit none
real ::  Thita_PD
double precision::pi
pi=3.1415926536d0
Thita_PD = 25
FUNCTION Acw(r)
real :: Acw
real, intent(in) :: r
Acw = 3*(r**2)*(cos(Thita_PD*pi/180d0)*((1/tan(30.0*pi/180d0))*cos(Thita_PD*pi/180d0)-sin(Thita_PD*pi/180d0)) &
+ Thita_PD*pi/180d0 + 30*pi/180d0 - pi/2)
END function Acw
end program FP
Since your function references things declared in the main program, what you want to do is make Acw a "contained" function. Add the single line:
CONTAINS
before the FUNCTION line. That will resolve the syntax error. I assume you're going to be adding a call to Acw somewhere (before the CONTAINS).
Andrew_F_1
Thanks for your reply. The point is that I'm gonna use the equation
16 + Thita_PD*pi/180d0 + 30*pi/180d0 - pi/2)
many times in my program so this is why I preferred to make it as a function. I tried doing what you told me but I got error #6633: The type of the actual argument differs from the type of the dummy argument.
program FP
implicit none
real ::  Thita_PD,x
 pi=3.1415926536d0
Thita_PD = 25
x=Awc(5)
Contains
FUNCTION Acw(r)
real :: Acw
END function Acw
end program FP
You want in line 9:
x = Acw(5.0)
5 is an integer and this doesn't match your declaration of the dummy argument as real.
mecej4
Line-9 has two errors. The function name is not spelled correctly, and the argument should be of type real; change "5" to "5.0".
Secondly, note that the function could be written more compactly as "acw=C*r*r", where C is a constant multiplier -- everything in the expression that you showed except for "r**2". This constant may be declared and computed in the main program once for all, before calling the function any number of times.
Andrew_F_1
Thanks guys a bunch. Solved
