Error?
reneeculver
The book arrived today!!!
Subroutine SetupExit
Use kernel32
Integer*4 FF
ff=SetupConsoleCntlrHandler(CloseWindow,.true.)
Return
End
Subroutine CloseWindow(number)
Integer*4 number
Return
End
I amcallingSetupExit but FFreturns a 1 which means an error ocurred. But what's the error?
Renee
reneeculver
Good eyes, Ian.
But when changed the DECL
I get this error:
Error 1 error LNK2019: unresolved external symbol CLOSEWINDOW1 referenced in function SETUPEXIT ASUBS.obj
Renee
IanH
Put the same (make a copy)
!DEC$ ATTRIBUTES STDCALL :: CloseWindow1
line immediately after the EXTERNAL statement in the SetupExit subroutine.
In addition to changing how the stack is handled and the way arguments are passed, STDCALL also directs the compiler to decorate the names used by the linker in a particular way. Remembering that each program unit (main program, external subroutine or function) in Fortran is independently compiled - so when compiling SetupExit the compiler knows nothing about ConsoleHandler1 apart from what you tell it (in the absence of being told otherwise, the compiler will make certain "implicit" assumptions about what ConsoleHandler1 is - hence without the EXTERNAL it thought ConsoleHandler1 was a REAL variable). If you mark ConsoleHandler1 as STDCALL in one program unit but not in the other program unit then the name used by the linker for ConsoleHandler1 will vary from program unit to program unit.
With the "1" missing from your !DEC$... statement, both program units thought that ConsoleHandler1 had the default calling convention, both program units would have given the same linker name to ConsoleHandler1 and so the link succeeded. (The problem that remained then was that the default calling convention used by ifort was not what the Windows operating system requires for these handling routines.)
When the function and subroutine are inside a module (as per my example - note that a module is a new variety of program unit added with Fortran 90), then the various procedures inside the module (known as module procedures) are not compiled independently. When compiling SetupExit the compiler inherently knows all there is to know about CloseWindow (and vice versa) - similarly any program units that then USE the module also gain complete knowledge about the routines. This is one of the compelling benefits of modules.
Note that when you are adding new stuff to legacy code there's nothing to stop you from putting your new code in a module and just popping a USE statement at the very top of the program unit that's going to be calling your new code. Similarly, there's nothing stopping you from sticking IMPLICIT NONE in at the start of your module - it only applies inside the module itself.
reneeculver
Ian,
I've copied your code into Exit1.f90.
MODULE RoutinesForHandlingTheConsole
IMPLICIT NONE ! Avoid bugs due to typos and confusion about type.
CONTAINS
SUBROUTINE SetupExit
USE KERNEL32, ONLY: SetConsoleCtrlHandler, BOOL, TRUE
INTEGER(BOOL) :: ff
ff = SetConsoleCtrlHandler(LOC(CloseWindow), TRUE)
END SUBROUTINE SetupExit
FUNCTION CloseWindow(number)
USE KERNEL32, ONLY: BOOL, DWORD, TRUE, FALSE
INTEGER(DWORD), INTENT(IN) :: number
INTEGER(BOOL) :: CloseWindow
INTEGER(DWORD) number
SELECT CASE (number)
CASE (0) ! Ctrl c
PRINT "('Oi!! Stop pressing Ctrl-C!')"
CloseWindow = TRUE
CASE (1) ! Ctrl break
PRINT "('Ouch!! That Ctrl-Break hurt!')"
CloseWindow = TRUE
CASE (2) ! Console Window close
PRINT "('Wait a tick - I don''t want to go away!')"
CloseWindow = TRUE
CASE DEFAULT ! 5 for log off, 6 for shutdown -
PRINT "('Bye bye!!')"
CloseWindow = FALSE
END SELECT
END FUNCTION CloseWindow
END MODULE RoutinesForHandlingTheConsole
I thought I was home until I recieved the following error....
Error 1 error #6418: This name has already been assigned a data type. [NUMBER] D:\System Utilities\Adventure\Adventure\Adventure(intel)\Adventure\Exit1.f90 15
Where has "number" already been assigned a datatype?
Renee
IanH
I can see two lines that declare number to be of type INTEGER(DWORD). I suggest you delete the second one without the INTENT(IN) clause, that is immediately before the SELECT CASE statement.
Note that to put short sections of code into your posts you can use the little yellow pencil (I think it's actually supposed to be a fluoro highlighter pen) that is in the toolbar.
reneeculver
Yes, you were right. I'll have to stop prograaming so late.
Now I have fixed that that problem....and...I think I have a linkage problem.
Error 1 error LNK2019: unresolved external symbol SETUPEXIT referenced in function MAIN__ AAMAIN.obj
How do I call it? I am currently calling it:
call SetupExit
Like that....
Renee
reneeculver
I got it....
Renee
reneeculver
I put the files back into where they used to be....Now I don't get a stack dump but I do hit a break point.
I'm willing to put this on hold for a while.....
Once again...thank you.
Renee
