Errors using GETPID()
Vishnu
GETPID() is a function that is part of the IFPORT module. I am using this function in a module called 'random.f90', which in-turn is USEd in the main program 'test_rand.f90'
  1. Upon not USEing IFPORT, compilation of the moduled results in the following error:
    $ ifort -c random.f90
    random.f90(47): error #6404: This name does not have a type, and must have an explicit type.   [GETPID]
                pid = GETPID()
    compilation aborted for random.f90 (code 1)
  2.  But if I add a USE IFPORT statement at the beginning, the compilation goes through without any errors, but linking results in an error I don't understand:
    $ ifort random.mod test_rand.f90
    test_rand.f90(3): error #6406: Conflicting attributes or multiple declaration of name.   [RANDOM]
        USE random
    compilation aborted for test_rand.f90 (code 1)
According to the IFPORT article, they are both valid way of using functions from the Portability module, but both run into errors. I am using the GETPID() function exactly as described in its Intel reference, with the variable 'pid' defined as an INTEGER.
Using Gfortran, the code compiles and runs correctly (of course, without the USE IFPORT statement), so, for portability, I would like to get it working without the explicit USE statement. Any ideas on what I might be doing wrong?
Kevin_D_Intel
You can make use of your own predefine to control the inclusion of the IFPORT module compile with either ifort or gfortran using the appropriate preprocessor options. The example below uses a predefine of IFORT to control inclusion of IFPORT. Use the additional compiler options -fpp -D IFORT with ifort and -cpp with gfortran as shown below.
module my_module
contains
  function get_pid() result(ipid)
#ifdef IFORT
    USE IFPORT
#endif
    INTEGER(4) ipid
    ipid = GETPID()
  end function get_pid
end module my_module
program example
use my_module
print *,'my pid=',get_pid()
end program example
$ ifort -fpp -D IFORT ex_getpid.f90 &&  ./a.out
 my pid=       29421
$ gfortran -cpp ex_getpid.f90 && ./a.out
 my pid=       29430
Kevin_D_Intel
You didn’t show your actual code but part of the problem relates to naming your module "random" within random.f90 and then the reference to that module in test_rand.f90 conflicts with the portability library name RANDOM hence you received the error #6406. Rename your module to something like "my_random" and change the usage to USE my_random.
Once that is corrected you will hit an new error with your compilation command line. You do not include the .mod file on the command line but rather the .o associated with the module definition. So assuming you rename only the module within your source file named random.f90, your command-line should be: ifort random.o test_rand.f90
To eliminate confusion you might want to rename your module as suggested and also the source file name to something like my_random.f90.
Vishnu
Ah! Okay, so I changed it to 'random_init', both the name of module, as well as the module file. Now it works, but only if I add a 'USE IFPORT' at the beginning. Is there any way I can get it to work without it?
Laura_S_3
Yes, you could declare GETPID at the top: integer, external :: GETPID but that is NOT recommended. What is your reason for not wanting to "use IFPORT"?
Vishnu
Why exactly is it not recommended? I do not want to 'USE IFPORT' because I want my code to also compile on gfortran without any errors.
Laura_S_3
When you use the "USE IFPORT" statement, then the compiler will be getting the information about GETPID from the IFPORT module. Presumably, the IFPORT module will have accurate information about GETPID. The "integer, external :: GETPID" way could tell the compiler incorrect information about GETPID, for example, if it is "integer(8)" instead of "integer". If the compiler has incorrect information, then your program is likely to run incorrectly.
Needing to be able to compile under gfortran is an important consideration. I suspect there is a safer way than to just state "integer, external :: GETPID" but I don't know it. Hopefully, one of the experts here will have a better way. Is it just gfortran and Intel Fortran you need to be able to compile with, or are there others?
Good luck!
Laura
Steve_Lionel
There is no guarantee that any of the "portability" procedures are implemented the same with other compilers. There are several I know of that have different interfaces and behaviors depending on the compiler. You're not guaranteeing portability by avoiding IFPORT.
Vishnu
I'm putting it at the very top of the MODULE file, after the IMPLICIT NONE and before the CONTAINS statement. Is that the right place? It complies and runs well with ifort, but under gfortran, the module file compiles, but linking gives errors, since GETPID is an intrinsic pocedure there.
$ gfortran random_init.o test_rand.f90
random_init.o: In function `__random_init_MOD_init_random_seed':
random_init.f90:(.text+0x96b): undefined reference to `getpid_'
collect2: error: ld returned 1 exit status
Yep, it is just ifort and gfortran.
I only need the code to also complie well in gfortran. Compliling and linking using gfortran requires no other statements. Is there any way I can write things that are only visible to ifort, but will be ignored by anyother compiler? Or: some way to write a line such that it will be ignored by gfortran, but be compiled by others?
Kevin_D_Intel
module my_module
contains
#ifdef IFORT
    USE IFPORT
#endif
    INTEGER(4) ipid
    ipid = GETPID()
program example
use my_module
end program example
 my pid=       29421
 my pid=       29430
Dandy_E_
module my_module
contains
#ifdef IFORT
    USE IFPORT
#endif
    INTEGER(4) ipid
    ipid = GETPID()
program example
use my_module
end program example
 my pid=       29421
 my pid=       29430
To avoid having to specify -DIFORT, one could use
#ifdef __INTEL_COMPILER
      USE IFPORT
#endif
where __INTEL_COMPILER is already/aotumatically defined by the intel compiler itself.
Vishnu
Dandy, that works! Thanks!
Kevin, i'm able to use those pre-processor directives only if I put them before the CONTAINS and IMPLICIT NONE statements:
MODULE random_init
    USE IFPORT
#endif
    IMPLICIT NONE
CONTAINS
    SUBROUTINE init_random_seed()
        USE iso_fortran_env, ONLY: int64
        INTEGER, DIMENSION(:), ALLOCATABLE :: seed
Kevin_D_Intel
Glad the predefine works for you. The #ifdef/endif directives are position-able anywhere within a source file. I'd have to see the explicit example where they were problematic for you to understand what the issue was. You would not want to include IMPLICIT NONE or the CONTAINS within the #ifdef/endif as that excludes them from the compiled source and at least w/o CONTAINS that breaks the source snippet shown and generates other compilation errors.
Anyway, glad you found a usable solution.
jimdempseyatthecove
You should be able to use strictly Fortran directives
!DIR$ IF DEFINED(__INTEL_COMPILER)
  USE IFPORT
!DIR$ ENDIF
Sometimes use of a preprocessor has undesirable side effects.
Jim Dempsey
Vishnu
Using this, I don't have to pass the -fpp or -cpp flags. That is really nice! Is that because those others are C directives?
EDIT: Oh, but there's another issue. Doing it this way breaks gfortran compatibility. It ow sees the 'USE IFPORT' line, and so returns an error. So looks like i'll have to use the earlier method.
Doesn't gfortran recognize !DIR$ ?
jimdempseyatthecove
Ahh..., See: https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/533979
Repeat Offender suggests:
!DEC$ IF(.FALSE.)
module ifport
end module ifport
!DEC$ ENDIF
FortranFan suggests writing your own interface.
Jim Dempsey
Vishnu
So why does gfortran not see these compiler directives? Are they not part of the fortran standard? Or are they very new?
Does the Intel reference page I linked to, put it in green because it is old stuff, or because it is specific to Intel-Fortran?
jimdempseyatthecove
Try !DIR$ in place of !DEC$
!DEC$ was used by Compaq Digital Fortran (which acquired Digital Equipment Corporation, aka DEC, Fortran). Intel acquired Compaq Digital Fortran. The !DEC$ ... was an inherited legacy.
Jim Dempsey
Steve_Lionel
In this case, I would recommend !DEC$. gfortran may recognize !DIR$. (I know it also recognizes !GCC$.) However, the _INTEL_FORTRAN preprocessor symbol won't be predefined in gfortran, so it doesn't matter whether or not gfortran recognizes the directive.
