29649 Discussions
Evaluating floating point operations crashes debugger
onkelhotte
New Contributor II
Hi there,
when I debug my code and I watch a line like
(length1+length2+length3)/3.
the debugger crashes and Dr. Watson wants to send an error report to mighty M$. The value in the watch window is
Unable to evaluate the expression. A serious internal error occurred while processing this command. The debugger may be unstable now. It is recommended that you save all files and exit.
Removing the dot brings me the right value.
This is annoying when I want to evaluate a more complex expression, because I have to remove every . in the formula.
Is that a Visual Studio 2008 problem or an IVF10.1 problem?
Thanks in advance,
Markus
It's an IVF problem - I can reproduce it, and MSVC doesn't do the same. I will report this to the developers. Intel issue DPD200047559.
This problem has been fixed in our sources. I expect the fix to appear in the next 10.1 update (September or later). Thanks for bringing it to our attention.
tboehme
Any news when this release will be available?
Debugging is really annoying without being able to use floting point expressions in the watch window.
regards,
Thomas
The next 10.1 update is currently scheduled for the last week of October.
You can also try the 11.0 beta - I think it's fixed there already.
