Exception Handling
thorium90
I played around a little bit with the IEEE_HANDLER() function from the Intel Fortran Library. I managed to produce a defind overflow exception behaviour as described in for_lib.pdf, pp. 2-108 ...2-110 So far so good.
But I was not able to get the handler working for integer overflow with the byte datatype. How can I enable integer overflow exception handling with ifc? Is this possible at all?
Michael
wjhenney
I too have been trying to get sensible exception handling
behavior out of ifc but I feel like I'm stumbling around
in the dark. What I really want is a compiler flag like
-ftrap=common, as found in the NAG compiler, that will
cause execution to be aborted on overflow, divide-by-zero,
or invalid operation.
Having failed to find one, I resorted to trying some of the routines described in the Intel Fortran Library,
namely setcontrolfpqq and ieee_flags but I can't claim
to understand what I'm doing.
In particular, what exactly is the difference in
functionalty between setcontrolfpqq() and ieee_flags()?
The only way I got an FP exception to abort execution
was by using _both_ of them (see example code below).
I found the descriptions in for_lib.pdf to be
very opaque and confusing. Also, the example code
snippets are in very non-standard fortran.
Any help or general enlightenment on the topic
would be much appreciated
Will
program fpetest
  use iflport
  implicit none
  integer :: iflag
  real :: x
  integer, parameter :: i2b = selected_int_kind(3)
  integer(i2b) :: control
  character(len=9) :: out
  ! find floating point processor control word
  call getcontrolfpqq(control)
  print '(b16.16)', control
  ! unmask common exceptions
  control = ibclr( control, 0 ) ! FPCW$INVALID
  control = ibclr( control, 2 ) ! FPCW$ZERODIVIDE
  control = ibclr( control, 3 ) ! FPCW$OVERFLOW
  call setcontrolfpqq(control)
  ! set the IEEE flags
  iflag = ieee_flags('set', 'exception', 'common', out)
  ! try to trigger an overflow
  x = 1.e30
  x = x/1.e-30
end program fpetest
wjhenney
Please excuse my previous post, which was full of
errors.
I've now got this to work with the getcontrolfpqq()
routine. The ieee_flags('set',...) function was a red herring - it seems to cause the next floating point operation, however innocuous, to raise an exception.
I append a revised demo program. By uncommenting each
of the three ibclr calls it falls over on a different
exception.
So I now have the -ftrap=XXX behavior that I wanted. Hopefully this will be of use to someone else. Doesn't help the OP with the integer exception problem though
(there is no SETCONTROLINTQQ routine....)
Will
yprogram fpetest
  use iflport
  implicit none
  integer :: iflag
  real :: x
!  control = ibclr( control, 2 ) ! FPCW$ZERODIVIDE
!  control = ibclr( control, 3 ) ! FPCW$OVERFLOW
  ! test of OVERFLOW
  x = 1.e30
  x = (x/1.e-30)**2
  ! test of ZERODIVIDE
  x = 0.0
  x = 1./x
  ! test of INVALID
  x = 0.0
  x = 0.0/x
end program fpetest
