Exception logging on Windows
frodoh
I have a Fortran based DLL hosted in a Windows application.  Is there a mechanism to dump the stack trace to a text file?
My suspicion is that the stack trace is written to standard out or standard error and I am not seeing it in release mode because I have no stdout/stderr.
andrew_4619
The environment variable "FOR_DIAGNOSTIC_LOG_FILE" can be used to set a log file name.
jimdempseyatthecove
You could follow the instructions in: Adding Console I/O to a Win32 GUI App
Another (untested) hack (try first):
Launch a CMD window, and then from the command line launch the executable (with necessary arguments). The idea with this is, the parent process is the CMD window, which has a console. The hope would be that the spawned process (your app  using the DLL) would inherit the file handles (console handles).
Jim Dempsey
Ron_Green
And once you have stdout and stderr open, then perhaps the https://docs.microsoft.com/en-us/cpp/c-runtime-library/reference/dup-dup2?view=msvc-170
_dup2() function can attach a file to that open file handle.
andrew_4619
