29567 Discussions
Executing a Windows program during a Fortran run
Paulo_M_
Hello everyone,
I am working on an optimization code, in which an external program should provide a data file, to be read by Fortran. My question is: how could I execute the external program during the Fortran run?
Paulo
DavidWhite
Valued Contributor II
Paulo,
You can call any command using SYSTEMQQ, which takes as an argument the command that you would use in a command or batch file.
Obviously, you would need to make sure your Fortran program closes any files needed, then you can call the program with a statement like
CALL SYSTEMQQ("C:\foldername\myprogram.exe argument1 argument2")
Then, when the program has completed, you can open the files to be analysed by your Fortran program.
David
EXECUTE_COMMAND_LINE would be more portable, but you'd need to find a replacement for Wordpad on Linux.
jimdempseyatthecove
export dboggs_EDITOR=gedit
IOW use an environment variable to provide the (partial) string for the EXECUTE_COMMAND_LINE.
You still have to work out issues regarding option switches and/or path separators /, \.
Jim Dempsey
