Execution error
Carlos_O_2
After i installed Fortran Compiller for Linux XW 2011 and tried to compile a sample code a see this message:
:/opt/intel/composer_xe_2013.0.079/Samples/en_US/Fortran/vec_samples$ ifort matvec.f90
ifort: error while loading shared libraries: libintelremotemon.so: cannot open shared object file: No such file or directory
Looking for a solution, i unistalled the software and re installed in an other PC, with the next results
:/opt/intel/composer_xe_2011_sp1.9.293/Samples/en_US/Fortran/vec samples# ifort matvec.f90
fortcom: No such file or directory
ifort: error #10273: Fatal error in fortcom, terminated by 0x64
Can anybody tell me what's wrong with it? Thank you so much
TimP
Did you check whether the missing compiler components are present on your system, with appropriate permissions, and that PATH and LD_LIBRARY_PATH include the relevant directories?
All this should work out if you use the provided install script and don't move the files afterwards, and source the compilervars scripts as instructed to set the paths.
You said you installed Composer XE 2011, but the error comes from Composer XE 2013.  Did you use the "source" command to make the Fortran environment available to you?  For example:
source /opt/intel/bin/compilervars.sh ia32
For the second error, you mistyped the path to the source file.
Carlos_O_2
Thanks for your time, i did what you're saying:
source /opt/intel/bin/compilervars.sh intel64
but nothing changed. And the second error, was my mistake. But checking and doing it again a have the same results.
Carlos_O_2
Thanks for your help. I'm new working with Linux, so could you help me with all process? I'm working in 64 bits kUbuntu SO
Piet_M_
I am having the same problem. Used the standard scripts to install Composer XE 2013. LD_LIBRARY_PATH is set. But when running icc the same error keeps occuring:
icc: error while loading shared libraries: libintelremotemon.so: cannot open shared object file: No such file or directory
The file libintelremotemon.so can not be found on the system with locate libintelremotemon.so
dwcloud
Just in case someone else comes along with this issue, the library exists.
cd to your top level installation path, e.g. /opt/intel/ and do a find:
find . -name "*remote*" -print
./composer_xe_2013.<version>/bin/ia32/libintelremotemon.so
./composer_xe_2013.<version>/bin/intel64/libintelremotemon.so
./composer_xe_2013.<version>/bin/intel64_mic/libintelremotemon.so
add this/these paths to your LD_LIBRARY_PATH in your login script and/or module file.
Uliana_V_
I have the same problem.
After installing Intel Fortran Composer on Ubuntu 12.04, I tried to compile a code and had a message:
I used
as it was recommended, but it retirned nothing.
mecej4
Uliana V. wrote:
I used
You have to change the current directory (cd) to the top level directory where Intel Fortran is installed. Otherwise, the search is started from the current working directory, and will, most likely, return nothing.
