29422 Discussions
Experience with Intel Fortran 2023.0.0 and Visual Studio 2022 version 17.4.3
van_der_merwe__ben
New Contributor II
Using Visual Studio 2022 version 17.4.3, I was able to install Intel Fortran 2023.0.0 without any issues. (I ran w_fortran-compiler_p_2023.0.0.25579_offline.exe.)
Fortran projects inside the solution showed up fine and the solution built without issue. However, moving the mouse over Fortran code while debugging failed to show most symbol information. This is a known issue, for which I ran the Visual Studio Installer and did a repair of Visual Studio 2022, and viola, it all works now.
With previous Intel Fortran versions, the solution would refuse to close or exit of you had any Fortran projects. That has clearly been fixed in 2023.0.0.
So thank you for 2023.0.0!
