29652 Discussions
F2003 Unlimited polymorphic pointer question
butette
I am trying to use unlimited polymorphic pointer to point to different derived ttype depending on some select criteria but just can't seem to get it to work with ifort 11.1. I boils it down to the following simple example
!--------------------- example up.F90 ----------------------------
module junk_mod
type, public :: junk
integer :: ijunk
end type junk
type, extends(junk), public :: junke
real :: rjunk=-1234.0
end type junke
end module junk_mod
program test
use junk_mod
type(junk), target :: junk1
type(junke), target :: junk1e
class(*), pointer :: junkup
junkup => junk1e
select type (junkup)
type is (junk)
print *, 'junkup: ', junkup%ijunk
type is (junke)
print *, 'junkup: ', junkup%ijunk, junkup%rjunk
end select
! This subroutine call does not work,
! although it looks like it is the same as the select section above
call uptest(junkup)
junkup => junk1
type is (junk)
type is (junke)
end select
call uptest(junkup)
end program test
subroutine uptest(this)
use junk_mod
class(*), pointer :: this
select type (this)
type is (junk)
print *, 'junkup: ', this%ijunk
type is (junke)
print *, 'junkup: ', this%ijunk, this%rjunk
class default
print *, 'unknown type'
end select
end subroutine uptest
as far as I can tell the inline code segment should be the same as what is in subroutine uptest, and yet when I run
with the uptest call, I would get a SIGSEGV, while the inline code would do the right thing.
Am I misunderstanding the usage of unlimited polymorphic pointer, or is thisa bug in the compiler ?
b.
Ben_Lauwens
Hello
The example compiles and runs without problems with ifort 11.1/072 when putting the subroutine in the main program:
program test
contains
end program test
I think an explicit interface is needed when the argument is a pointer.
I hope my answer is useful.
Ben
butette
Hi Ben,
Thanks for the reply. Yes, I know that if you make it an internal subroutine (using contains) it will work because that is like having the code segment in place explicitly. While I don't see anywhere that says that I need an explicit interface for an external subroutine if I want to pass a pointer, but that looks like it is the problem. Well, at least I tried it and it seems to work.
I will go read the language definition again to see what I was missing.
I am telling you, F2003 rules are too complicated.
Thanks again!
Butette
An explicit interface is needed when a dummy argument is either a pointer or is polymorphic.
If you compile with the "-warn interface" option the compiler will complain:
t.f90(32): warning #8055: The procedure has a dummy argument that has the ALLOCATABLE, ASYNCHRONOUS, OPTIONAL, POINTER, TARGET, VALUE or VOLATILE attribute. Required explicit interface is missing from original source. [JUNKUP]
call uptest(junkup)
t.f90(47): warning #8055: The procedure has a dummy argument that has the ALLOCATABLE, ASYNCHRONOUS, OPTIONAL, POINTER, TARGET, VALUE or VOLATILE attribute. Required explicit interface is missing from original source. [JUNKUP]
call uptest(junkup)
butette
Thank you Steve... I guess I have not noticed that requirement in my normal usage before through module procedure with polymorphic argument, but I have never try to use it with an UP pointer before.
You might also read my old article Doctor Fortran Gets Explicit, though this was written for F95. In general, I recommend using explicit interfaces everywhere, ideally by putting your procedures in modules. Failing that, use "-warn interface". I have noted and reported, though, that this doesn't warn for a missing interface when you have a polymorphic dummy argument that isn't a pointer.
