FORALLs and /Qparalell
Greynolds__Alan
Does IVF parallelize all FORALL statements/blockswith the/Qparallel option? If not, shouldn't it be able to since by definition the iterations of a FORALL are independent and reference onlyPURE functions with no side-effects?
Al Greynolds
www.ruda-cardinal.com
No - the semantics of FORALL end up making it very difficult to parallelize. This is why Fortran 2008 added DO CONCURRENT, which is "FORALL done right". I will note that FORALL is not a loop, so talking about iterations can be confusing. It is effectively an array assignment.
Greynolds__Alan
Thanks for the tip Steve. I just read John Reid's discussion of FORALL versus DO CONCURRENT inftp://ftp.nag.co.uk/sc22wg5/N1701-N1750/N1729.pdf Does this mean that IVF will parallelize all DO CONCURRENT blocks if I switch from FORALLs?
Al
Intel Fortran 11.1 doesn't support DO CONCURRENT. Support will be added in a future release. The compiler will attempt to parallelize DO CONCURRENT constructs if you use /Qparallel - there's no guarantee of parallelization, but the odds are good.
j_clausen
SoFORALL is pretty much obsolete, then?
j_clausen
In my opinion, yes.
j_clausen
Why must the "DO CONCURRENT" be invented? Couldn't Intel just change the way FORALL is implemented and make that the "FORALL done right"?
It maybe a dumb question with an obvious answer, but bear with me, a mere civil engineer and occasionalIVF user :-)
j_clausen
TimP
The limited step which ifort has taken which may correspond with your suggestion is the facility to optimize FORALL in certain contexts with !DIR$ IVDEP. Changing the meaning of standard syntax, even under a compiler option, has continually proven unsatisfactory. No doubt, the standards committee wrestled with this question, and decided a new keyword would be the better solution.
It's not a question of "implementation", but rather, as Tim says, of semantics. We can't change the meaning of a program that uses FORALL just because it doesn't parallelize well.
