FORTRAN Reinstallation Problem
Jingcheng_Li
Since I just found that Visual Studio 2010 doesn't support Visual FORTRAN 11 right now, I try to uninstall Visual Studio 2010 and Visual FORTRAN 11, then install Visual Studio 2008 first then Visual FORTRAN 11. I want to ask:
Is there any problems when I reinstall Visual FORTRAN, since the license only allow it installed in one computer?
If I want to set up FORTRAN environment in Visual Studio 2008, need I install VS first then FORTRAN? The order is important? Or is there any other way to set FORTRAN environment in VS 2008?
Jingcheng
The license allows you to install on as many computers as you want, as long as you are the only user of the compiler on that computer (other users need their own license.)
What you suggest for installing with VS2008 should work.
