29647 Discussions
FORTRAN calling C# DLL - Examples please
David_Caruthers
I am mainly a classoc VMS FORTRAN programmer that can write some C# and othe languages. Recently ported a large engineering/estimating system for VMS FORTRAN to Intel VIsual FORTRAN. THis works but has problems with internal datatable maintenace. The mandate is to replace the table routines with database lookup using C# database access routines.
Are there any good examples of using the Intel Visual FORTRAN Module Wizard to access C# dll. I would appreciate a fair amount of detail. Also none of the people here know how to setup C# to work with the module wizard. Help!
I have used a work around where I spawn a C# program that goes to the database retrieves the data and leaves a file for the FORTRAN but this is a little to slow when a large number of queries are to be done.
Are there good examples of using the module wizard or something else to go directly to a SQL Server databas from IVF?
Thank in advance.
David
anthonyrichards
New Contributor III
Here's how one poster handled the passing of character strings between C# and Fortran and vice-versa:
http://software.intel.com/en-us/articles/handling-character-strings-between-c-and-fortran/#comment-36878
If you do web searches, you should be able to find stuff to help you with arrays of variables etc.
Equivalent data types can be found here:
http://software.intel.com/en-us/articles/equivalent-data-types-between-fortran-and-c_sharp/
David_Caruthers
Thank you for the help but the call is going in the wrong direction. It is the FORTRAN routine that will be doing the calling. I am having difficulty writing any routines in C# and making them callable from FORTRAN. The FORTRAN is driving so to speak.
David
anthonyrichards
New Contributor III
A recent thread here (http://software.intel.com/en-us/forums/showthread.php?t=78835&o=a&s=lr) showed how Fortran could call VB .NET by first making a VB .NET Class Library DLL containing the methods (functions) that you want the Fortran to call and making the DLL COM-visible. Then you make a Type library from the DLL and then use the Fortran Module Wizard on the Type library to generate the COM calls to the Class library methods exposed via COM. That way should work for C# as it also is object-oriented like VB .NET.
Arjen_Markus
We use a C++ layer in between the Fortran program and the C# subroutines/functions. I do not know the details, unfortunately, but that seems to work fine. (No time now to look them up ;))
Arjen
Jugoslav_Dujic
Valued Contributor II
Quoting arjenmarkus
Us too. Here's an example, with a complete solution:
http://software.intel.com/en-us/forums/showthread.php?t=77818
