FORTRAN sqrt:DOMAIN error
rhballou
I am running a program under Windows 7 with Compaq Visual Fortran version 6.6B containing a square-root function. The M6201:MATH sqrt:DOMAIN run-time error occurs. I have verified that thevalue of the variable sentto the DSQRT functionis positive and the variable is REAL*8. The QuickWin library is used. Are there other reasons besides a negative argument that can cause the error?
Jugoslav_Dujic
Valued Contributor II
A NaN (or possibly also Inf) would also trigger it, if I recall correctly.
rhballou
Thanks for reply. I am not familiar with NaN. Can it be corrected or how is it treated?
Jugoslav_Dujic
NaN comes as result of floating-point operation which has undefined result. The most common case is 0./0., and there are other possibilities, such as Inf/Inf, Inf*0., etc.
Why don't you run your program through debugger, and find out for yourself?
