29647 Discussions
Failure in creating and using a DLL: Error R6034
Arjen_Markus
I am trying to create and use a simple Fortran DLL butthat results in an error message
"R6034: An application has attempted to load the C runtime library incorrectly"
This is with Intel Fortran 11.1 on Windows XP.
Here are my compile and build commands:
ifort mydll.f90 -dll
ifort myprogram myprogram.f90 mydll.lib
and the code:
--- mydll.f90 ---
module prng_factory
implicit none
integer, parameter :: type_uniform = 1
integer, parameter :: type_exponential = 2
type, abstract :: prng
! No data
contains
procedure(get_next), deferred :: get
end type
abstract interface
real function get_next( params )
import :: prng
class(prng) :: params
end function get_next
end interface
type, extends(prng) :: prng_uniform
real :: xmin, xmax
contains
procedure :: get => get_uniform
end type
type, extends(prng) :: prng_exponential
real :: xmean
contains
procedure :: get => get_exponential
end type
contains
real function get_uniform( params )
!DEC$ attributes dllexport :: get_uniform
class(prng_uniform) :: params
real :: r
call random_number( r )
get_uniform = params%xmin + (params%xmax-params%xmin) * r
end function get_uniform
real function get_exponential( params )
!DEC$ attributes dllexport :: get_exponential
class(prng_exponential) :: params
real :: r
get_exponential = -params%xmean * log( r )
end function get_exponential
function prng_create( type, param1, param2 )
!DEC$ attributes dllexport :: prng_create
integer :: type
real :: param1
real, optional :: param2
class(prng), pointer :: prng_create
type(prng_uniform), pointer :: uniform
type(prng_exponential), pointer :: exponential
select case (type)
case (type_uniform)
allocate( uniform )
prng_create => uniform
case (type_exponential)
allocate( exponential )
prng_create => exponential
case default
nullify( prng_create )
end select
select type (prng_create)
type is (prng_uniform)
if ( present(param2) ) then
prng_create%xmin = param1
prng_create%xmax = param2
else
prng_create%xmin = 0.0
prng_create%xmax = param1
endif
type is (prng_exponential)
prng_create%xmean = param1
end select
end function prng_create
end module prng_factory
--- myprogram.f90 ---
program test_prng_factory
use prng_factory
integer :: i
p => prng_create( type_uniform, 1.0, 2.0 )
do i = 1,10
write(*,*) p%get()
enddo
p => prng_create( type_exponential, 10.0 )
do i = 1,10
write(*,*) p%get()
enddo
end program test_prng_factory
This works fine on Linux (using Intel Fortran 12) and with gfortran on Windows XP (but then
I do not have to worry about the DLLEXPORT stuff).
What am I doing wrong?
Arjen
mecej4
No problems building and running with 11.1.070 or 12.0.4.196 (both targeting IA32) on W7-X64.
EIther you are using an earlier version than 11.1.070, or there is some problem with the configuration/environment.
Arjen_Markus
Good to hear that. I just turned off the machine I ran it on, so I can not check it at the moment.
I wil check further tomorrow.
Arjen
You need to add /libs:dll to the link of the main program. The DLL implicitly has that because of -dll. What is happening is that your EXE does not have the correct manifest to cause loading of the MSVCRT DLL but it is also linking to the static MSVC library. The effects of this on XP are what you saw. On Windows 7 you may get a "DLL not found" error.
Arjen_Markus
Thanks! I will try that - that serves me right for avoiding the Visual Studio environment ;). But for such
small programs I find it a very heavy environment.
Arjen
Arjen_Markus
Yes, that solved the problem! I removed the DLLEXPORT directives from the get_uniform and get_exponential functions and the program still worked. I guess these are not required, because they are resolved at run-time?
Arjen
If the procedure is not called from outside the DLL, you don't need DLLEXPORT.
Arjen_Markus
Well, I am trying to understand the consequences - if there are any - of having an object with
type-bound procedures in a DLL. I guess that getting back the object from an (exported)function/subroutine
in the DLL is enough to make these type-bound procedures available in the calling program. They are
not invoked directly from my program.
I see some interesting possibilities here (a "plugin archtecture").
Arjen
Right. The type-bound procedures end up as entries in a table with references resolved when the DLL is linked. The use of the TBPs through the type don't require DLLEXPORT. If you called the procedures directly by name, passing the object explicitly, you would need DLLEXPORT.
