File not find during link
Hang_S_
I'm working in a Linux system ( Ubuntu 12.04 ), using ifort linking the main program main.f90 and library lib.a. If I use command
ifort main.f90 /home/tom/lib/lib.a
then everything is fine. But if I use
ifort -L/home/tom/lib main.f90 lib.a
then ifort gives an error
ifort: error #10236: File not found:  'lib.a'
Why the -L specification doesn't work? When I want to use the environment variable LIBRARY_PATH ? It still gives me that error, why that happen? Must I specify the full path every time I link the library?
Kevin_D_Intel
Libraries on Linux are found using -L (and/or LIBRARY_PATH) along with the lower-case "l" (i.e. -l<name> ) option. When using -l you leave off the leading "lib" portion of the library name as the linker automatically prepends "lib" to the name when searching for it, so if your library is named libEXP.a, then you link using something like:
ifort -L/home/tom/lib -lEXP main.f90
You will need add some additional characters to your library name and not try using a library named lib.a.
Hope that make sense.
Kevin_D_Intel
Hang_S_
Thank you very much! It works!
Kevin_D_Intel
Great. Glad that helped.
