Final subroutine not invoked
Bálint_A_
Dear All,
It seems, that intel 16.0.3 (I do not have any more recent version currently) shows non-standard behavior when doing finalization: Given a derived type without a final subroutine, but with an allocatable component with final subroutine, the final subroutine of the allocatable component is not invoked, when a given instance of the derived type is finalized.
The example below demonstrates the issue. The destructor of MyType is never invoked, although the allocatable array, where it is stored, should be finalized, when the instance of MyTypeWrapper is goes out of scope (is deallocated).
Bálint
module testmod
  implicit none
  type :: MyType
    integer :: data = 0
  contains
    final :: destruct
  end type MyType
  type :: MyTypeWrapper
    type(MyType), allocatable :: container(:)
  end type MyTypeWrapper
contains
  subroutine destruct(this)
    type(MyType), intent(inout) :: this
    print *, 'Destroying:', this%data
    this%data = 0
  end subroutine destruct
end module testmod
program testifort
  use testmod
  type(MyTypeWrapper), allocatable :: wrapper
  allocate(wrapper)
  allocate(wrapper%container(1))
  wrapper%container(1)%data = 1
  deallocate(wrapper)
  allocate(wrapper)
  wrapper%container(1)%data = 2
  deallocate(wrapper)
  print *, 'DONE'
end program testifort
Bálint_A_
For some reasons I can not edit the post above. The code contains a typo, as the destructor should be defined for rank one objects. The correct version is, which is not treated by the compiler as it should follows:
module testmod
  implicit none
  type :: MyType
    integer :: data = 0
  contains
    final :: destruct
  end type MyType
contains
    type(MyType), intent(inout) :: this(:)
    this%data = 0
end module testmod
program testifort
  use testmod
  allocate(wrapper)
  deallocate(wrapper)
  allocate(wrapper)
  deallocate(wrapper)
  print *, 'DONE'
Kevin_D_Intel
Thank you for reporting this. I'll investigate.
Kevin_D_Intel
ifort handles the polymorphic case CLASS(MyTypeWrapper) successfully but not the case you presented. I reported your case to Development.
(Internal tracking id: DPD200414065)
