Finalization of derived types
drraug
In Fortran 2003 standard finalization of derived types is proposed by "final :: " keyword, that could be included in the specification of type. Consider the following example
[fortran]module test_mod
 type mytyp
  double precision, allocatable :: a(:,:)
 contains
  final :: mytyp_finalize
 end type
contains
 subroutine mytyp_finalize(arg)
  implicit none
  type(mytyp),intent(inout) :: arg
  if(allocated(arg%a))deallocate(arg%a)
 end subroutine
end module
[/fortran]
I have the following error during compilation.
[bash]$ uname -a
Linux localhost 2.6.28-11-generic #42-Ubuntu SMP Fri Apr 17 01:58:03 UTC 2009 x86_64 GNU/Linux
$ ifort -V
Intel Fortran Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1    Build 20091130 Package ID: l_cprof_p_11.1.064
Copyright (C) 1985-2009 Intel Corporation.  All rights reserved.
FOR NON-COMMERCIAL USE ONLY
$ ifort t.f90
t.f90(5): error #5082: Syntax error, found '::' when expecting one of: ( % : . = =>
t.f90(5): error #6590: This statement is not permitted as a statement within a derived-type-def
t.f90(6): error #8295: The type bound procedure part in derived type definition must have at least one procedure binding statement.
 end type
compilation aborted for t.f90 (code 1)
[/bash]
Does this mean that finalization is not avaliable in the current version of Intel Fortran Compiler? Do you plan to add finalization in the nearest future?
Ron_Green
correct, FINAL is not currently supported. This will be coming in the next major version of the compiler, tendatively scheduled for fall 2010.
ron
Ron_Green
ron
drraug
Thank you, Ron!
