- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Is it possible to use font and text functions createfont , gettxtmetrics etc in a dos program?
I generate graphics out put for a third part program and need to know the font characteristics - charcater widths etc.
I would like to supply a font as the typeface and the use Gettextmetrics to obtain the dimensions of each character.
If not are there any oher programs available to provide this information
- Marcas:
- Intel® Fortran Compiler
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
This is the type ofroutine i am looking for - to use the font routines in a FORTRAN CONSOLE PROGRAM - without having a winmain entry, The value of hfont returning from createfont has a value, however the ABCD array from getcharwidth32 and lptm%tmAscent from Gettextmetrics are zero because HDC is zero , I am not sure about BeginPaint (hWnd
___________________________________________________
integer function getfontwidths()
use gdi32
use dfwin
use dflogm
use dfwinty
use dflib
USE DFNLS
implicit none
integer ftwide(256)
character*90 typeface
integer hfont,hdc,hwnd
integer i,j,nhgg,nw, ret,nchars
real fact
integer lenstr
integer ABCD(0:255)
type (T_PAINTSTRUCT) ps
typeface="Arial"
typeface(6:6)=char(0) ! needs null terminator
hdc = BeginPaint (hWnd, ps)
nhgg=-10000
nw=0
hfont = CreateFont(-nhgg, nw, 0, 0, 0, 0, 0, 0, &
DEFAULT_CHARSET, OUT_TT_PRECIS, CLIP_DEFAULT_PRECIS, &
PROOF_QUALITY,INT(DEFAULT_PITCH) ,typeface)!
nchars=255
ret=selectobject(hdc,hfont)
ret=getcharwidth32 (hdc,1,nchars,LOC(ABCD(1)))
ret=Gettextmetrics(hdc,lptm)
fact=10000./lptm%tmAscent
do j=32,nchars
ftwide(j)=ABCD(j)*fact
write(6,*)j,ftwide(j)
enddo
return
end
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Only got fortran version 6.1 , can the winprint example be obtained from internet , or any ideas to get a device
steve
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Basically, you can call most GDI functions from a console application, but you have to better define what you're aiming at. For example, you can call hDC = GetDC(NULL)...ReleaseDC() to obtain the current screen DC (although you shouldn't draw on it, only take the data from it) -- rather than BeginPaint, which makes no sense outside of a window procedure. You can also call CreateCompatibleBitmap+CreateCompatibleDC to create an off-screen DC, with which you can do as pleased (even save it as a bitmap).
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thanks Juroslav - the GETDC(NULL) did the trick
steve
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
HI Juroslav - I think the program is nearly there - the version i got now is
_______________________________________________________________
use dfwin
use dflib
implicit none
character*10 font(3),typeface
integer abcd(0:255)
FONT(1)="COUR"
FONT(2)="ARIAL"
FONT(3)="BOOKOS"
font(1)(5:5)=char(0)
font(1)(6:6)=char(0)
font(1)(7:7)=char(0)
do i=1,3
hdc = getdc(null)
nhgg=-10000
nw=0
hfont = createfont(-nhgg, nw, 0, 0, 0, 0, 0, 0, &
default_charset, out_tt_precis, clip_default_precis, &
proof_quality,int(default_pitch) ,font(i))!
nchars=255
ret = gettextface(hdc ,10,typeface)
ret=getcharwidth32 (hdc,1,nchars,loc(abcd(1)))
write(6,*)font(i)(1:10), "-" ,typeface(1:10)
do j=32,nchars
write(66,*)j,abcd(j)
enddo
enddo
ret=releasedc(null,hdc)
stop
end
and get thescreen output
COUR -Arial
ARIAL -Arial
BOOKOS -Arial
I seem not to be clearing the "Arial" from the handles for hfont and HDC
Steve
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- You should check whether hFont = CreateFont(...) succeeds. (hFont.NE.0). I don't think that Windows is smart enough to deduce the intent of "Cour" or "Bookos"
- CreateXXX GDI functions are tiresome because you have to do the bookeeping of object deletion and selection. You need instead:
if (hFont.NE.0) then
hOldFont = SelectObject(hDC, hFont)
ret = SelectObject(hDC, hOldFont)
ret = DeleteObject(hFont)
else
!error
end if
P.S. it's far more elegant to initialize the character variables as font(2)="Arial"//char(0).
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
STill no joy - my program is now
use dfwin
use dflib
implicit none
integer hfont,hdc,hwnd,holdfont
integer abcd(0:255)
FONT(1)="COUR"//char(0)
FONT(2)="dutch"//char(0)
FONT(3)="BOOKOS"//char(0)
do i=1,3
hdc = getdc(null)
nhgg=-10000
nw=0
nchars=255
holdfont=selectobject(hdc,hfont)
write(6,*)font(i)(1:10), "-" ,typeface(1:10),abcd(60)
holdfont=selectobject(hdc,holdfont)
else
write(6,*)'Error'
endif
enddo
stop
end
COUR -Arial 5227
ARIAL -Arial 5227
BOOKOS -Arial 5227
Arial does not even appear in the code now but comes out in the output !!! . if i use the same instructions in a "normal" windows graphics program using winmain etc everything is OK
steve
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
The following, however, works for me (enlarge the string sizes):
FONT(1)="Courier New"//char(0)
FONT(2)="Arial"//char(0)
FONT(3)="Times"//char(0)Producing:
Courier New -Courier New 5298
Arial -Arial 5227
Times -Times 5093
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
