Forcing subroutine usage
clunk
I don't now if I inadvertently changed a setting or if VS 2005 changed something with an update, but what used to work is now broken. I have a relatively large solution that uses a combination of my code and supplied libraries (called out in the top-level project of the solution). In some cases, I have subroutines in my code that I would like to have supercede an identically named subroutine in the supplied libraries. Previously, if I ensured that the build order accessed my version of the subroutine prior to the top-level project, then my code would be used. Right now, I can't get the program to use anything but what is in the supplied libraries (thus ignoring my code). Any ideas or suggestions on how to make VS 2005 and Intel Fortran (10.1) cooperate with my desires???
If you turn on the Linker option Show Progress Messages (/verbose), it will tell you the order in which it looked at objects and libraries and the symbols found from each. This may give you a clue.
clunk
Thanks Steve. I had been down the verbose road before, but this time I noticed that the subroutine in question had to be invoked somewhere before it's made available in order to have the Linker findmy desired version.
You may want to look at the Linker "Force symbol reference" property, then.
