Fortcom error
edmund_ryanshef_ac_u
I'm new to Fortran. I've just tried compiling some code, but get the following error message:
Description File
1 Severe: No such file or directory fortcom
2 Compilation Aborted (code 1) DALEC_EnKF.f90
(DALEC_EnKF is my project file consisting of 5 source code files). Does anyone know what 'fortcom' means? and how I can fix this? - I'm really stuck.
Cheers,
Ed
Les_Neilson
Valued Contributor II
Description File
Cheers,
Ed
"fortcom" is the Fortran Compiler
The first error message saysit cannot find it. You need to ensure that your PATH contains the full path to where you installed the compiler.
I assume you running it from the command line and not from Visual Studio ?
Les
Quoting - Les Neilson
Les
That helps. Sorry I should have said, I am using visual studio in windows to run the compiler.
I'll try and correct the path.
Ed
Les_Neilson
Ed
If you are compiling from within Visual Studio and getting the error message then that would imply the installation of the compiler was incorrect, as the integration with VS automatically sets the appropriate paths.
(note: The order of installation is VS then the Fortran compiler.)
You may need to re-run the "integration" part of the compiler install.
What version of VS and what version of the Intel compiler are you using?
Les
Les
It's all working now. You were right - it wasn't installed correctly. Many thanks for all your help Les.
Ed
