Fortran 11.1 installation problem
Harish_A_
I have installed the Intel Visual Fortran for IA-64 on my computer. But getting the following error when I run ifortvars.bat:
 “D:\Program files\Microsoft Visual Studio 11.0\VC\SetEnv” is not recognisedas an internal or external command, operable program or batch file.
 I wanted to know if using Visual Studio 11.1 might be the problem or if it is the path that I am using ?
You almost certainly installed the wrong compiler. Unless you are developing for Intel Itanium processors, you want the "Intel 64" compiler (or the installer that provides both IA-32 and Intel 64 compilers.) In any case it should not be looking for Visual Studio 11.
Harish_A_
Hi Steve,
Thanks for the help. I got it to work.
Harish
