Fortran 18 compiler
Roberto3
How can I get an Intel Fortran 18 compiler? Thank you
Steve_Lionel
Do you mean a compiler supporting Fortran 2018, or version 18.0 of the compiler? If the former, see The Easy and Fast Way to Install JUST Fortran with Intel® oneAPI - Intel Communities.  If the latter, you would need to have a paid support contract get it from the Intel Registration Center, though I would question why you think you need that.
Roberto3
Thank you very much Steve
yes, I need version 18.0 of the compiler as I received a PSCAD model that was probably comipiled with version 18.0. I'm investigating if that's the reason why I can't run it.
Steve_Lionel
No, that would not be a reason. What is the problem symptom? If there's an error message, please show a screenshot. If the error is that there are missing DLLs, then you should just need to install the run-time redistributables. Go to Intel® oneAPI standalone component installation files . In the left column, select "Runtime Versions" and select your OS.
