Fortran 2003 feature implementation
MDK
Is there a timeline for the planned release of Fortran 2003 features that aren't implemented yet? I'm particularly interested in polymorphic allocation and the FINAL and GENERIC keywords for type-bound procedures.
Polymorphic allocation is already supported, unless I misunderstand what you're referring to. Support for FINAL and GENERIC is planned for late 2010, but that's subject to change.
MDK
By polymorphic allocation I mean something like this:
[fortran]function alloc(x)
    implicit none
    class(object), intent(in) :: x
    class(object), allocatable :: obj
    allocate (obj, source=x)
end alloc[/fortran]
With 11.1.054 I get the following compilation error for such constructs:
error #5415: Feature not yet implemented: SOURCE=polymorphic_expression
Ok, I thought you meant something like allocate(type(foo)::x). What you describe is also planned for late 2010.
yamajun2
I encountered similar problem. In my case CLASS object can be ALLOCATE (i.e. no syntax error), but runtime error occurs.
Here is the output and code.
Yamajun
draw circle 10.00000 10.00000 6.000000
draw circle 40.00000 12.00000 10.00000
location = 20.00000 10.00000
location = 60.00000 2.000000
draw rectangle 20.00000 10.00000 35.00000 10.00000
draw rectangle 60.00000 2.000000 15.00000 8.000000
forrtl: severe (157): Program Exception - access violation
Image PC Routine Line Source
test2.exe 00401DE2 _MAIN__ 80 test2.f90
test2.exe 004A9DD3 Unknown Unknown Unknown
test2.exe 0044E0D3 Unknown Unknown Unknown
test2.exe 0044DE9D Unknown Unknown Unknown
kernel32.dll 7D4F7D42 Unknown Unknown Unknown
[fortran]MODULE m_shape
IMPLICIT NONE
  TYPE :: t_shape
    REAL :: x = 0.0 , y = 0.0
  CONTAINS
    PROCEDURE :: location
  END TYPE t_shape
CONTAINS
    SUBROUTINE location(this)
      CLASS (t_shape), INTENT(IN) :: this
      PRINT *, 'location =     ', this%x, this%y
      RETURN
    END SUBROUTINE location
END MODULE m_shape
MODULE m_test
USE m_shape
IMPLICIT NONE
  TYPE, EXTENDS(t_shape) :: t_circle
    REAL :: r = 0.0
  CONTAINS
    PROCEDURE :: draw => draw_circle
  END TYPE t_circle
  TYPE, EXTENDS(t_shape) :: t_rectangle
    REAL :: dx = 0.0, dy = 0.0
  CONTAINS
    PROCEDURE :: draw => draw_rectangle
  END TYPE t_rectangle
CONTAINS
  SUBROUTINE draw_circle(this)
    CLASS (t_circle), INTENT(IN) :: this
    PRINT *, 'draw circle    ', this%x, this%y, this%r
    RETURN
  END SUBROUTINE draw_circle
  SUBROUTINE draw_rectangle(this)
    CLASS (t_rectangle), INTENT(IN) :: this
    PRINT *, 'draw rectangle ', this%x, this%y, this%dx, this%dy
    RETURN
  END SUBROUTINE draw_rectangle
END MODULE m_test
PROGRAM test
USE m_test
IMPLICIT NONE
  TYPE (t_circle   ), ALLOCATABLE :: c(:)
  TYPE (t_rectangle), ALLOCATABLE :: r1, r2
  CLASS (t_shape)   , ALLOCATABLE :: s1, s2
  ALLOCATE( c(2) )
  c(1) = t_circle(10.0, 10.0,  6.0)
  c(2) = t_circle(40.0, 12.0, 10.0)
  ALLOCATE( r1, SOURCE = t_rectangle(20.0, 10.0, 35.0, 10.0) )
  ALLOCATE( r2, SOURCE = t_rectangle(60.0,  2.0, 15.0,  8.0) )
  CALL c(1)%draw()
  CALL c(2)%draw()
  CALL r1%location()
  CALL r2%location()
  CALL r1%draw()
  CALL r2%draw()
  DEALLOCATE( c, r1, r2 )
  ALLOCATE( s1, SOURCE = t_rectangle(20.0, 10.0, 35.0, 10.0) ) ! Crash here
  ALLOCATE( s2, SOURCE = t_rectangle(60.0,  2.0, 15.0,  8.0) )
  CALL s1%location()
  CALL s2%location()
  STOP
END PROGRAM test
 [/fortran]
Yamajun,
This is a compiler bug that will be fixed in a future update. As a workaround, set the project properties Fortran > Diagnostics > Generate Interface Blocks and Check Routine Interfaces to No.
yamajun2
Steve,
Thanks! Now it runs fine! I thought I've tried those options after reading your reply in some other thread, but maybe I made some silly mistake.
There is, however, another problem with TYPE, ABSTRACT. I encounter syntax error#8212.
Here is a sample code.
Yamajun
IMPLICIT NONE
  TYPE, ABSTRACT :: t_shape
    CONTAINS
    PROCEDURE (p_draw), DEFERRED :: draw
  END TYPE t_shape
  ABSTRACT INTERFACE
    SUBROUTINE p_draw(this)
      IMPORT :: t_shape
    END SUBROUTINE p_draw
  END INTERFACE
END MODULE m_shape
MODULE m_test
USE m_shape
IMPLICIT NONE
    REAL :: x, y
    REAL :: r
  CONTAINS
  END TYPE t_circle
CONTAINS
    PRINT *, 'Darw circle   ', this%x, this%y, this%r
    RETURN
END MODULE m_test
PROGRAM test
USE m_test
IMPLICIT NONE
  TYPE (t_circle) :: c1
  TYPE (t_circle) :: c2
  c1 = t_circle(10.0, 5.0, 6.0)  !error #8212: Omitted field is not initialized. Field initialization missing:
  ALLOCATE( c2, SOURCE = t_circle(10.0, 5.0, 3.0) ) !error #8212:
  STOP
END PROGRAM test[/fortran]
Thanks, Yamajun, I agree that this is incorrect behavior. I have escalated it as issue DPD200149810.
Douglas_Peplow
Is the implementation of allocation using a polymorphic still on track for this year?
[bash]module demo_module
implicit none
type, public, abstract :: parent_type
    character(12) :: name
    integer :: codeNumber
end type parent_type
contains subroutine someMethod(object) implicit none class (parent_type), intent(in) :: object class (parent_type), allocatable :: copy allocate(copy,source=object) ! error #5415: Feature not yet implemented: SOURCE=polymorphic_expression end subroutine someMethod end module demo_module [/bash]
pbkenned1
ALLOCATE(source=polymorhic) won't be in the initial release of the next major version of the compiler, which is planned for November. It might be provided in a subsequent update, or perhaps even a subsequent major version.
If parent_type were not abstract, typed allocation might be a workaround, for example,
ALLOCATE(something_derived_from_parent_type :: copy)
Patrick Kennedy
Intel Developer Support
FINAL and GENERIC are in Intel Visual Fortran Composer XE 2011, aka 12.0, available now.
