29309 Discussions
Fortran 2015 Downloaded Professional Got Cluster
chauvjo
I downloaded the Intel® Parallel Studio XE Professional Edition for Fortran and C++ Linux* (all tools) and appear to have actually downloaded the Intel® Parallel Studio XE Cluster Edition for Linux* (all tools).  The installer specifically says Cluster Edition. Both files are exactly the same size which does not seem right. Can someone please check to see if the correct versions are associated with the given link under My Intel Products.  If something has changed that I missed, please let me know.
Thanks....
Kevin_D_Intel
I will look into this and reply when I have more information.
Kevin_D_Intel
Through colleagues I confirmed that we intentionally provide the same download file for the Intel® Parallel Studio XE 2015 Cluster and Professional Editions as you noted and further clarified that the appropriate components are decoded/installed based on the license file provided at installation time.
For the CE/PE installation, the following Welcome dialog appears which tries to convey its support for both the Cluster and Professional Editions:
Welcome to the Intel(R) Parallel Studio XE 2015 for Linux* installation program.
Install one of the following products:
Intel(R) Parallel Studio XE 2015 Cluster Edition for Linux*
Intel(R) Parallel Studio XE 2015 Professional Edition for Fortran and C++ Linux*
Intel(R) Parallel Studio XE 2015 Professional Edition for C++ Linux*
Intel(R) Parallel Studio XE 2015 Professional Edition for Fortran Linux*
Your current license actually affords you the use of all the components within the Cluster Edition, and we confirmed the versions associated with your Intel Products under the Intel Registration Center are correct.
Hope that helps clarify the situation.
chauvjo
Thanks Kevin.  It appears the installer does not give you the option of installing a subset of the licensed components.  For various reasons, not every user is going to always want to install the full product as enabled by the license.  The Welcome dialog you showed gives the impression the installer is going to give you a choice based on your license.  If so, I must have missed this feature while running the installer.  If you are licensed for the Cluster Edition and you want to install only the Professional Edition, this should be an option.  Please let me know if this is possible with the new installer.
Kevin_D_Intel
The installer affords the ability to tailor installed components individually and not by the Edition packaging in Step 5 : Options as shown in the details below.
Step 1 of 7 | Welcome
You will complete the steps below during this installation:
Step 1 : Welcome
Step 2 : License agreement
Step 3 : Activation
Step 4 : Intel(R) Software Improvement Program
Step 5 : Options
Step 6 : Installation
Step 7 : Complete
Press "Enter" key to continue or "q" to quit:
Upon reaching Step 5, after selecting the default option 1 to Finish configuring cluster [default], a Pre-install Summary appears as shown below.
Step 5 of 7 | Options
This product can be installed on cluster nodes.
1. Finish configuring cluster [default]
2. Configuration type                           [ Current node ]
h. Help
b. Back to the previous menu
q. Quit
Please type a selection or press "Enter" to accept default choice [1]: 1
Step 5 of 7 | Options > Pre-install Summary
Install location:
    /opt/intel/parallel_studio_xe_2015
Component(s) selected:
    Intel(R) MPI Library, Development Kit 5.0 Update 1                     738MB
        Intel(R) MPI Library, Runtime Environment for applications running on Intel(R) 64 Architecture
        Intel(R) MPI Library, Runtime Environment for applications running on Intel(R) Many Integrated Core Architecture
        Intel(R) MPI Library for applications running on Intel(R) 64 Architecture
        Intel(R) MPI Library for applications running on Intel(R) Many Integrated Core Architecture
    Intel(R) Trace Analyzer and Collector 9.0 Update 1                     310MB
        Intel(R) Trace Analyzer for Intel(R) 64 Architecture
        Intel(R) Trace Collector for Intel(R) 64 Architecture
        Intel(R) Trace Collector for Intel(R) Many Integrated Core Architecture
    Intel(R) VTune(TM) Amplifier XE 2015                                   655MB
        Command line interface
        Sampling Driver kit
        Graphical user interface
    Intel(R) Inspector XE 2015                                             270MB
    Intel(R) Advisor XE 2015                                               430MB
    Intel(R) C++ Compiler XE 15.0                                          566MB
        Intel C++ Compiler XE
    Intel(R) Fortran Compiler XE 15.0                                      245MB
        Intel Fortran Compiler XE
    Intel(R) Math Kernel Library 11.2                                      1.8GB
        Intel MKL core libraries
        Intel(R) Xeon Phi(TM) coprocessor support
        Fortran 95 interfaces for BLAS and LAPACK
        GNU* Compiler Collection support
        Cluster support
    Intel(R) Integrated Performance Primitives 8.2                         2.0GB
        Intel IPP single-threaded libraries: General package
    Intel(R) Threading Building Blocks 4.3                                  69MB
        Intel TBB
    GNU* GDB 7.7                                                           130MB
        GNU* GDB 7.7 on Intel(R) 64 (Provided under GNU General Public Licensev3)
        GDB Eclipse* Integration on Intel(R) 64 (Provided under Eclipse Public License v.1.0)
    Intel(R) MPI Benchmarks 4.0                                              4MB
Install Space Required:     7.4GB
Driver parameters:
    Sampling driver install type: Driver will be built
    Drivers will be accessible to everyone on this system. To restrict access,
        select Customize Installation > Change advanced options > Driver is accessible to
        and set group access.
    Load drivers: yes
    Reload automatically at reboot: yes
    Per-user collection mode: no
Cluster installation type:
    Product will be installed on a single node
Install VTune Amplifier data collectors on Intel(R) Xeon Phi(TM) coprocessors: yes
Restart Intel MPSS: yes
1. Start installation Now [default]
2. Customize installation
h. Help
q. Quit
At the prompt following the Pre-install summary, select option 2, Customize Installation, to select the Architecture and then option 3 to finish that selection.
Step 5 of 7 | Options > Architecture selection
Select the architecture(s) where your applications will run. If unsure, accept
the default options below or see
http://software.intel.com/en-us/articles/about-target-architecture-selection-du
ring-installation for more information.
Target Architecture(s) of your applications:
1. [ ]    IA-32
2.     Intel(R) 64
3. Finish architecture selection [default]
Note: This system is an Intel(R) 64 architecture system.
Your application may be built to run on either IA-32 or Intel(R) 64 architectures.
q. Quit
Please type a selection or press "Enter" to accept default choice [3]: 3
After selecting the Architecture, then select option 3, Change components to install, to tailor the individual components to install.
You are now ready to begin installation. You can use all default installation
settings by simply choosing the "Start installation Now" option or you can
customize these settings by selecting any of the change options given below
first. You can view a summary of the settings by selecting "Show pre-install
summary".
2. Change install directory      [ /opt/intel/parallel_studio_xe_2015 ]
3. Change components to install  [ Custom ]
4. Change advanced options
5. Show pre-install summary
h. Help
q. Quit
Please type a selection or press "Enter" to accept default choice [1]: 3
Step 5 of 7 | Options > Component selection
Select the component you wish to install. When you have completed your changes,
select option 1 to continue with the installation.
1. Finish component selection [default]
2. Intel(R) MPI Library, Development Kit 5.0 Update 1 [All]
3. Intel(R) Trace Analyzer and Collector 9.0 Update 1 [All]
4. Intel(R) VTune(TM) Amplifier XE 2015 [All]
5. Intel(R) Inspector XE 2015 [All]
6. Intel(R) Advisor XE 2015 [All]
7. Intel(R) C++ Compiler XE 15.0 [Custom]
8. Intel(R) Fortran Compiler XE 15.0 [Custom]
9. Intel(R) Math Kernel Library 11.2 [Custom]
10. Intel(R) Integrated Performance Primitives 8.2 [Custom]
11. Intel(R) Threading Building Blocks 4.3 [All]
12. GNU* GDB 7.7 [Custom]
13. Intel(R) MPI Benchmarks 4.0 [All]
Install Space Required:     5.8GB
h. Help
q. Quit
To install the equivalent of the Professional Edition when using a Cluster Edition license file, select the components 2 and 3 as shown above to disable the installation of those components. The example below only shows de-selecting Intel(R) Trace Analyzer and Collector 9.0 Update 1.
You may choose not to install some components of this product. Optional
components are shown with an option number of the left. Entering that number
will select/unselect that component for installation. When you have completed
your changes, select option 1 to return to previous menu.
2.  Intel(R) Trace Analyzer and Collector 9.0 Update 1
3.      Intel(R) Trace Analyzer for Intel(R) 64 Architecture
4.      Intel(R) Trace Collector for Intel(R) 64 Architecture
5.      Intel(R) Trace Collector for Intel(R) Many Integrated Core
Architecture
Install Space Required:     310MB
h. Help
q. Quit
Please type a selection or press "Enter" to accept default choice [1]: 2
2. [ ] Intel(R) Trace Analyzer and Collector 9.0 Update 1
3.     [ ] Intel(R) Trace Analyzer for Intel(R) 64 Architecture
4.     [ ] Intel(R) Trace Collector for Intel(R) 64 Architecture
5.     [ ] Intel(R) Trace Collector for Intel(R) Many Integrated Core
Architecture
Install Space Required:       0MB
h. Help
q. Quit
3. Intel(R) Trace Analyzer and Collector 9.0 Update 1 [None]
Install Space Required:     5.5GB
h. Help
q. Quit
Once the components selections are complete, select the default Finish Component Selection, and either review the pre-install summary again or use option 1 to start the installation as shown below.
summary".
h. Help
q. Quit
