Fortran/C++ binding error
alphajet
I was trying to run a simple binding example between Fortran/C++, where Fortran calls a C++ function, the files are:
(cprog.cpp) C++
[cpp]#include void print_C(char *string) /* equivalent: char string[] */{ printf("%s\n", string); } int main (void){ return 0; }[/cpp] (fprog.f90) Fortran
[bash]program main use iso_c_binding, only: C_CHAR, C_NULL_CHAR implicit none interface subroutine print_c(string) bind(C, name="print_C") use iso_c_binding, only: c_char character(kind=c_char) :: string(*) end subroutine print_c end interface call print_c(C_CHAR_"Hello World"//C_NULL_CHAR) pause end[/bash] I then attempt to run the files as follows:
1- compiling the C++ source:
cl /EHsc cprog.cpp
2- compiling the Fortran source
ifort fprog.f90 cprog.obj
But I get the following error:
unresolved external symbol print_C
which is the C++ function I'm trying to use.
Note: the example I copied these codes from didn't have a main function in the C++ source file, so when I tried to compile the C++ source, it threw me an error:
unresolved external symbol main
but the error went away when I declared the main function, and I'm now stuck at the print_C error
Thanks in advance
JVanB
Valued Contributor II
Get rid of the main() function in your C++ code. Instead compile with the /c (compile only) switch.
C++ mangles names unless you tell it not to. You must give print_C() the extern C attribute. Thus:
extern "C" void print_C(char *string)
JVanB
alphajet
Thanks alot, it's working now !
Thanks for your prompt and to-the-point reply
