Fortran/C++ pointers
maksyutov__malik
Hello!
There is some main C++ code that will calling a fortran subroutine,
#include <cstdlib>
#include <iostream>
using namespace std;
 *  Fortran/C++ interoperability
extern "C" void Fortran_f(double**, int);
int main()
    int i, sz =10;
    double **AG;
    AG=new double*[sz];
    for (i=0;i<sz;i++)AG=(double*)malloc(sizeof(double));
//  Do something with AG
    Fortran_f(AG,sz);
    return EXIT_SUCCESS;
C-function "malloc" for the reallocation purposes in C++ main was using(however, will be provided by the fortran function later).
How to pass AG object to the Fortran function?
My first try is,
SUBROUTINE FORTRAN_F(PAG,SZ)BIND(C,name="Fortran_f")
USE, INTRINSIC :: ISO_C_BINDING
IMPLICIT NONE
TYPE(C_PTR)     :: PAG
INTEGER, INTENT(IN), VALUE :: SZ
TYPE PRV
      DOUBLE PRECISION, POINTER :: PA(:)
END TYPE
INTEGER                                                  :: I, J, M, N
DOUBLE PRECISION.                             :: X
TYPE(PRV)                                               :: P_PAG
TYPE(PRV),POINTER,DIMENSION( : )   :: AG
TYPE(C_PTR), POINTER                        :: CPAG
CALL C_F_POINTER(PAG,CPAG)
ALLOCATE(AG(SZ))
DO I = 1, SZ
          CALL C_F_POINTER(CPAG,AG(I)%PA)
ENDDO
!  Do something in Fortran code
!           AG  =>REALLOCATE(AG, new_size) ! My own realloc function
DO I = 1, M
      DO J = 1, N
            AG(I)%PA(J)=AG(I)%PA(J)+SIN(X)
      ENDDO
ENDDO
END SUBROUTINE.
Unfortunately, it didn't work with the following error:
  forrtl: severe (408): fort: (7): Attempt to use pointer PA when it is not associated with a target
WHAT'S WRONG?
jimdempseyatthecove
Only one of the languages should perform the allocations, reallocations and deallocations of objects.
Look at the documentation for the C interoperability features, in particular the means to use/pass Fortran descriptors to C/C++ programs.
As an additional note.
Fortran uses descriptors into an allocatable array that is contiguous. IOW this is not an array of pointers to rows of data.
In C/C++ it is more efficient to allocate a 2D array as a 1D array, possibly sticking the pointer into the C/C++ pointer[0] of the row table, then populate the row table for each stride into the blob that constitutes the 2D array.
Jim Dempsey
maksyutov__malik
Many Thanks Jim!
