29381 Discussions
Fortran Compiler 9.1 standard evaluation copy (for windows)
mechanicsjie
Could anybody please tell me where can I find the link of download for 'Fortran Compiler 9.1 standard evaluation copy'? I can find the latest evaluation copy of 'Fortran Composer XE 2011', but not sure if I can still get the older version of fortran compiler if I request this latest one.
My computer is 32bit and have ABAQUS 6.9 installed (or 6.10). I also have Microsoft Visual C++ 2005 Express and Microsoft Platform SDK (X86) as pre-requisite software ready for the fortran compiler. Is it a good combination which will work with ABAQUS 6.9 (or other versions)? Will the fortran compiler 9.1 be ok in this case? Please advise.
Thanks a lot!
We generally do not make older versions available for download for evaluation users, but it may be that if you request an evaluation copy and are assigned a serial number, you can register that serial number at the Intel Registration Center and then use the instructions here to get an older version.
I can't tell you aboiut ABAQUS compatibility but you will be able to use the 9.1 compiler in command line mode with that configuration.
mechanicsjie
That's so fast! Thank you so much for your quick response! I'll get an evaluation copy of the latest version and give a try. :)
