Fortran & Matlab
klamat2
Hello NG,
I'm looking forward to mex fortran code with ivf 8.1 in the matlab environment under windows 2000.
So far ivf is not supported by mathworks i need help to rewrite the df66opts.bat or the intelc71opts.bat to work with intel visual fortran 8.1 - hints I found in some ng's are all for linux.
- Matthew
Jugoslav_Dujic
Valued Contributor II
Does this thread help?
Jugoslav
klamat2
Thank's for this hint, but my problem is the opposit using of matlab and fortran - i want to call fortran code compiled with ivf 8.1 from the matlab environment ...
- Matthew
g_f_thomas
IIRC this can be done with Matlab 14 which dispenses with the mex and allows you to load a classic/AX dll. Check it out on the MathWorks site.
HTH,
Gerry T.
klamat2
Hallo G.F.
You're right regarding the matlab interface to generic dll's, but the advantage of the old-fashioned mex is the absence of necessity to change the "high-level" m-code, thats is calling the fortran subroutines.
- Matthew
os3
For anyone who whishes to build MATLAB mex dll's with ifc 8.1:
I have attached an archive with two options files to be put into the "%MATLAB%inwin32mexopts " directory.
After copying the files, use "mex -setup", it should find the compiler and install the "mexopts.bat" file
(at least on two machines :-).
To build a mex dll, one of the issues is (as mentioned before) to link the dll with the correct libraries using the correct calling convention. In these options files I have chosen the CVF calling convention and linking against the df60 libraries; appears to work for my projects. I have not yet tested all mex library calls (but "mexErrMsgTxt" and some others work).
The setup script is a hack of other scripts; one of the issues is that one actually needs to set two `root' directories in the mexopts.bat file, and I do not think the matlab mex setup process allows for that. This script therefore assumes a environment var to get around that. See the warning.
(no guarantees ;- )
BJ
os3
update of scripts, see attachment
