Fortran Preprocessor: #endif creates a blank line
Wentao_Z_
Hi ,
I have a quick question regarding the #ifdef and #endif for preprocessing. I have the following code piece in my fpp file:
#ifdef USE_SIMD
              !DIR$ SIMD
#endif
              do i = is, ie
                dF(i + offset_kj) = dF(i + offset_kj) + value * F(i + offset_ii)
              end do
After preprocessing, I got the following code piece in the f90 file:
!DIR$ SIMD
              do i = is, ie
              end do
There is a blank line between the SIMD directive and the do i loop. I think it is generated by the #endif directive. Is there an easy way to avoid this? I want the SIMD directive to be next to the do i loop.
I would truly appreciate your help!
    Wentao
Kevin_D_Intel
Development indicates there is no way to suppress this blank line with fpp. Sorry.
Kevin_D_Intel
I have not found a way. fpp seems to be operating consist with cpp in this regard also. I inquired with our Developers whether this is possible and will let you know what they say.
TimP
I haven't encountered adverse effects from this.  I make extensive use of fpp insertion of omp simd in view of the need to make it conditional on __MIC__.
Kevin_D_Intel
jimdempseyatthecove
Have you tried:
#endif  do i = is, ie
Jim Dempsey
Wentao_Z_
Thanks for your reply. If the blank line does not influence how !DIR$ SIMD works, then that's fine.
Wentao_Z_
jimdempseyatthecove wrote:
Have you tried:
Jim Dempsey
Thanks for your reply. But this does not work since the preprocessing will "eat" the do i loop.
jimdempseyatthecove
If you are inclined to use FPP to create a source file that you keep, as opposed to an intermediary file to use as source, then you could easily write a script to remove blank lines following !DEC$ SIMD (and tidy up other things).
Jim Dempsey
Wentao_Z_
Jim Dempsey
Thanks for your suggestion:-)
Best,
Wentao
