I am migrating a large number of VS 6.0 mixed language C++/CVF Fortran projects (500+) to VS.NET and the Intel Fortran compiler. I can migrate the projects manually using the Integrated ?Extract Compaq Visual Fortran Project Items? function in VS.NET but I would like to use the extensive automation tools built into VS.NET to automate the migration process and manage the projects in the future. I found the VFProject and VFProjConvert objects but I can?t find any documentation, samples or tech support on how to use them. Since I know there are probably many other developers struggling with this problem I thought I would post and see if there is an elegant solution to this problem or whether I should contact support directly.
-Travis
-Travis
Did you find the answer to your questions?
Because I find it horribly difficult to migrate from CVF to Intel-
and no help at all from the support or documentation-
Please if you have more knowledge help me with some tips.
Thank you
Ioana Vais : i.vais@ucl.ac.uk
Thank you
