29655 Discussions
Fortran coarray config file name problem
tcu
I wanted to test coarrays with oneAPI 2022 (and same problem with 2023)
When I try to run, mpiexec crunches because it can't find the config file.  The reported filename has weird extra characters (same every time).
$ ifx -coarray=distributed -coarray-config-file=$HOME/caf.cfg demo.f90
$ ./a.out
[mpiexec@xeonmax] HYD_parse_configfile (../../../../../src/pm/i_hydra/mpiexec/mpiexec_params.c:1110): unable to open config file: /gpfs/home/arcurtis/caf.cfgintr#int#4
[mpiexec@xeonmax] parse_compound_configfile (../../../../../src/pm/i_hydra/mpiexec/mpiexec_params.c:1219): error parsing config file /gpfs/home/arcurtis/caf.cfgintr#int#4
[mpiexec@xeonmax] mpiexec_get_parameters (../../../../../src/pm/i_hydra/mpiexec/mpiexec_params.c:1482): no executable specified
[mpiexec@xeonmax] main (../../../../../src/pm/i_hydra/mpiexec/mpiexec.c:1783): error parsing parameters
TobiasK
@tcu
we fixed the config-file problem in our development version and the fix will be included in the next release.
TobiasK
thanks for reporting this, will get that bug fixed.
in the meantime, you can use the environment variable to overwrite the file name:
FOR_COARRAY_CONFIG_FILE=$HOME/caf.cfg ./a.out
tcu
Thanks for the workaround.  Here's what happens now with a completely empty program.  "-n 1 ./a.out" in the config file.  Ditto for "single" coarray mode.
$ ifx -coarray=shared -coarray-config-file=$HOME/caf.cfg empty.f90
$ FOR_COARRAY_CONFIG_FILE=$HOME/caf.cfg ./a.out
[xm002:422794:0:422794] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x39)
==== backtrace (tid: 422794) ====
 0 0x0000000000054df0 __GI___sigaction()  :0
 1 0x000000000002efd8 uct_ib_mlx5_devx_md_get_pdn()  ???:0
 2 0x0000000000032202 uct_ib_mlx5_devx_create_cq()  ???:0
 3 0x000000000001cc86 uct_ib_md_close()  ???:0
 4 0x000000000001ce11 uct_ib_md_close()  ???:0
 5 0x00000000000650d3 ucs_rcache_create_region()  ???:0
 6 0x000000000001d5f6 uct_ib_iface_estimate_perf()  ???:0
 7 0x0000000000037f3f ucp_request_purge_enqueue_cb()  ???:0
 8 0x000000000003fe68 ucp_memh_get_slow()  ???:0
 9 0x00000000000401b8 ucp_memh_get_slow()  ???:0
10 0x000000000004129b ucp_mem_map()  ???:0
11 0x00000000000094dd mlx_mr_regattr()  osd.c:0
12 0x00000000000095b8 mlx_mr_regv()  osd.c:0
13 0x00000000000095fa mlx_mr_reg()  osd.c:0
14 0x000000000063299a fi_mr_reg()  /p/pdsd/scratch/Uploads/IMPI/other/software/libfabric/linux/v1.9.0/include/rdma/fi_domain.h:313
15 0x000000000063299a win_allgather()  /build/impi/_buildspace/release/../../src/mpid/ch4/netmod/ofi/ofi_win.c:206
16 0x0000000000247467 MPIDIG_mpi_win_create()  /build/impi/_buildspace/release/../../src/mpid/ch4/src/ch4r_win.c:821
17 0x0000000000265a22 MPID_Win_create()  /build/impi/_buildspace/release/../../src/mpid/ch4/src/ch4_win.c:109
18 0x000000000079ca0c PMPI_Win_create()  /build/impi/_buildspace/release/../../src/mpi/rma/win_create.c:173
19 0x00000000000174e2 for_rtl_ICAF_INIT()  ???:0
20 0x0000000000407c34 for_rtl_init_()  ???:0
21 0x00000000004048cd main()  ???:0
22 0x000000000003feb0 __libc_start_call_main()  ???:0
23 0x000000000003ff60 __libc_start_main_alias_2()  :0
24 0x00000000004047d5 _start()  ???:0
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   RANK 0 PID 422794 RUNNING AT xm002
=   KILLED BY SIGNAL: 11 (Segmentation fault)
i
TobiasK
Did you verify that Intel MPI is working properly on your setup?
Can you please add '-genv I_MPI_DEBUG=10' to the config file and post the result?
tcu
A simple hello-world type MPI program runs fine.
If I run the executable directly there's no MPI debugging output.  If I run it explicitly via mpirun, I get the below before the seg fault messages:
[0] MPI startup(): Intel(R) MPI Library, Version 2021.6  Build 20220227 (id: 28877f3f32)
[0] MPI startup(): Copyright (C) 2003-2022 Intel Corporation.  All rights reserved.
[0] MPI startup(): library kind: release
[0] MPI startup(): libfabric version: 1.13.2rc1-impi
[0] MPI startup(): max number of MPI_Request per vci: 67108864 (pools: 1)
[0] MPI startup(): libfabric provider: mlx
[0] MPI startup(): File "/gpfs/software/intel/oneAPI/2022_2/mpi/2021.6.0/etc/tuning_icx_shm-ofi_mlx_400.dat" not found
[0] MPI startup(): Load tuning file: "/gpfs/software/intel/oneAPI/2022_2/mpi/2021.6.0/etc/tuning_icx_shm-ofi_mlx.dat"
[0] MPI startup(): threading: mode: direct
[0] MPI startup(): threading: vcis: 1
[0] MPI startup(): threading: app_threads: -1
[0] MPI startup(): threading: runtime: generic
[0] MPI startup(): threading: progress_threads: 0
[0] MPI startup(): threading: async_progress: 0
[0] MPI startup(): threading: lock_level: global
[0] MPI startup(): tag bits available: 20 (TAG_UB value: 1048575)
[0] MPI startup(): source bits available: 21 (Maximal number of rank: 2097151)
[0] MPI startup(): Rank    Pid      Node name  Pin cpu
[0] MPI startup(): 0       754023   xm001      {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,
                                 30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56
                                 ,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,8
                                 3,84,85,86,87,88,89,90,91,92,93,94,95}
[0] MPI startup(): I_MPI_ROOT=/gpfs/software/intel/oneAPI/2022_2/mpi/2021.6.0
[0] MPI startup(): I_MPI_MPIRUN=mpirun
[0] MPI startup(): I_MPI_HYDRA_TOPOLIB=hwloc
[0] MPI startup(): I_MPI_HYDRA_BOOTSTRAP=slurm
[0] MPI startup(): I_MPI_INTERNAL_MEM_POLICY=default
[0] MPI startup(): I_MPI_DEBUG=10
TobiasK
There have been some issues with Intel MPI which should have been fixed with 2023.2, can you please update the Intel MPI also?
tcu
Waiting for new version to be installed.   Will check back.  Thanks.
TobiasK
any news from your side?
tcu
Nothing yet.  Apparently there were some issues with MPI in 2023.2 here.
TobiasK
Ok, I will wait until end of the week, if they do not manage to install the updated MPI, please open a new thread if the issue remains with Intel MPI 2021.10.
Your compute center should consider opening a priority support ticket to resolve the Intel MPI upgrade issue or you may post a problem description in the Intel HPC toolkit forum:
https://community.intel.com/t5/Intel-oneAPI-HPC-Toolkit/bd-p/oneapi-hpc-toolkit
TobiasK
@tcu
