29389 Discussions
Fortran compiler output directory
JimH_7
I am trying to integrate some existing software to an new OS (Oracle Linux Server 8.5")
When I ran CMake (which compiles C++ and Fortran code) it seems the output file for Fortran does not exist on this new machine and OS.
I get this error message in the CMakeError.log:
Compiling the Fortran compiler identification source file "CMakeFortranCompilerId.F" failed.
Compiler: /pkg/intel/Compiler/11.0/083/bin/intel64/ifort
Build flags:
Id flags:
The output was:
127
/pkg/intel/Compiler/11.0/083/bin/intel64/ifort: line 57: /opt/intel/Compiler/11.0/083/bin/intel64/ifortbin: No such file or directory
Ron_Green
Odd - does the file exist?  /opt/intel/Compiler/11.0/083/bin/intel64/ifortbin
It should.  I see it in my older installation of 11.0 084.
When you set up for the compilation with your bash shell environment, you did this yes?:
source /pkg/intel/Compiler/11.0/083/bin/ifortvars.sh intel64
did you get any errors when you did this?
You are not using a batch system to submit jobs are you?
And you get this output to these 2 command?  Well SIMILAR output for your /pkg/intel directory path :
 which ifort
/cts/tools/compiler/cpro/Compiler/11.0/084-dbg/bin/intel64/ifort
which ifortbin
/cts/tools/compiler/cpro/Compiler/11.0/084-dbg/bin/intel64/ifortbin
Barbara_P_Intel
I wonder if there may be issues running an older compiler like this one on a modern OS. Did you check the release notes?
