29651 Discussions
Fortran debugger, missed breakpoints.
jct_office
I am trying to test out Fortran Visual Studio 2008 (9.0) using the x64 bit platform.
I have written an extremely simple program, and I have discovered that, when debugging, all of my set breakpoints are skipped. That is, a) I select several breakpoints for the program to stop at, and b) hit the green > key to run in debug mode. Without stoppingat any of the setbreakpoints, the program runs to completion.
What is going wrong.have we mis-installed something?Is there some environment setting I need to set?
Any help will be appreciated.
There was a compiler bug in the first 10.1 release that had this symptom. As far as I know, it is fixed in the current update, 10.1.021.
