29393 Discussions
Fortran ftell returning to wrong position
Mincheol
When I have used Intel Parallel Studio 2015 or gfortran, it is working good.
But After I updated last version  which is Intel Parallel Studio 2020 update 4, It is working bad.
And when I tested that compiler option which is Multithreaded or Multithread dll, the results were different.
If you run attached, You can know compiler has a bug.
Barbara_P_Intel
Thank you all for the additional information!
I filed a bug, CMPLRLIBS-33377. I'll let you know its progress to a fix.
mecej4
The output from Intel Fortran 2016.0.8 is correct, the first three lines being:
 FTELL Test
           1           0          14                    14                    14
           2           0          28                    28                    28
The output from the 19.1.3 version as well as the OneApi latest compilers is:
 FTELL Test
           1           0          14                    14                    14
           2           0          14                    14                    14
Mincheol
When can Intel fix it?
Barbara_P_Intel
I'll take a look at it.  What OS are you running on?  I get different output on Linux. It's not correct, just different than your incorrect output.
What compiler options are you using?
Please post the complete output from the program.  It's only 11 lines.
Thanks!
MWind2
New Contributor III
My test on W10:
FTELL Test
           1           0          14                    14                    14
           2           0          14                    14                    14
           3           0          28                    28                    28
           4           0          42                    42                    42
           5           0          56                    56                    56
           6           0          70                    70                    70
           7           0          84                    84                    84
           8           0          98                    98                    98
           9           0         112                   112                   112
          10           0         126                   126                   126
 Compiler version:
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel
(R) 64, Version 2021.2.0 Build 20210228_000000
Compiler options:
/nologo /debug:full /Od /warn:interfaces /module:x64\Debug\ /object:x64\Debug\
/Fdx64\Debug\vc160.pdb /traceback /check:bounds /check:stack /libs:dll /threads
/dbglibs /c /Qlocation,link,C:\Program Files (x86)\Microsoft Visual Studio\201
9\Professional\VC\Tools\MSVC\14.28.29910\bin\HostX64\x64 /Qm64
Added
 use ISO_FORTRAN_ENV
    write(*,*)" Compiler version: ",compiler_version()
    write(*,*)" Compiler options: ",compiler_options()
Mincheol
My OS is Windows 10.
The result is below.
Thank you.
Barbara_P_Intel
Barbara_P_Intel
@Mincheol  The issue you reported with ftell is fixed in the Fortran compiler 2021.4.0. It was released last week as part of oneAPI HPC Toolkit.
Can you please download the new compiler and check it out? Let me know how it works for you.
Mincheol
I have finished to check it.
It worked good.
Thank you.
Barbara_P_Intel
That's great news! I consider this case closed.
