29352 Discussions
Fortran interface to call a C function that returns a pointer to an array
GeoffH
Back again after being away for quite a while...
After much searching, I found what I believe to be the closest answer to my problem is on stackoverflow (SO) at https://stackoverflow.com/questions/3852790/fortran-interface-to-call-a-c-function-that-return-a-pointer, (posted nearly 10 years ago!)
I quote this because using that example keeps the code simple and still illustrates my problem.
I want to return an array that has been created/memory allocated in C++ and be able to analyse the answer in Fortran, because that is where the bulk of the code for this application lies. My application goes off into C++ to produce the integer array answer and returns it to the Fortran program via the C interface. The original SO example used a single double precision variable as the return. I’ve changed it to integer because that is what I will be dealing with in my application. The example code (as changed) works.
I have highlighted with comments the changes that I have tried to make to return an array pointer, but I’ve run out of ideas. (I could say, “Oh for the bad old days when I could just equivalence an integer to an iarray(1) and go beyond the size of the array”, but I won’t. It’s good to have coding protections, but sometimes it gets frustrating.)
I am using Visual Studio 2017 and Intel Fortran parallel_studio_xe_2019_update5_composer.
My modified example of the original SO code:
[code here
! ps_test_pointers.f90
program foo
  use, intrinsic :: iso_c_binding, only : c_ptr,        &
                                          c_f_pointer,  &
                                          c_int
  implicit none
  type(c_ptr) :: c_p!(:) ! <-------
  integer(c_int), pointer :: f_p!(:) ! <-------
  interface
    function foofunc() bind(c)
      import :: c_ptr
      implicit none
      type(c_ptr) :: foofunc!(:) ! <-------
    end function foofunc
  end interface
  c_p = foofunc()
  call c_f_pointer(c_p, f_p)
  print *, f_p
end program foo
// ps_test_pointersC.cpp : 'Subroutine' only.
extern "C" {
    int bar[3] = { 2, 3, 4 };
       int *foofunc() {
        return bar;
As I said above, the code works, in the sense that it prints out the first element of the array (‘2’).
If I add the ‘(:)’ to the definition of f_p, the code compiles without error, but when I run it, the program fails with the run-time error: “forrtl: severe (408): fort: (7): Attempt to use pointer F_P when it is not associated with a target” at the line “call c_f_pointer(c_p, f_p)”.
I have tried declaring c_p as an array (“c_p(:)”), but I get the same error in the same place.
I have also tried calling c_p as an argument to a subroutine – still only using integers
[code here
program foo
                                          c_f_pointer,  &
                                          c_int
  implicit none
  interface
    subroutine foofunc(c_p) bind(c)
      import :: c_ptr
      implicit none
    end subroutine foofunc
  end interface
  call foofunc(c_p)
  print *, f_p
end program foo
extern "C" {
       void foofunc(int *rtn) {
        rtn = bar;
but the created pointer in the C function never gets assigned to c_p on return (hence f_p is never defined).
Reading around the problem, I hope I’m not at the bleeding edge of compiler implementation and have exposed a problem between restrictions tightening but not coping with all the use cases!
Is there a solution to this? Any?
Contributions will be gratefully received!
Arjen_Markus
I think you are working a trifle too hard here:
type(c_ptr) :: c_p(:) would be an array of C pointers, not a C pointer to a C array.
type(cptr) :: c_p is the one you need, because C returns an array and whatever is behind that address is of no interest to the declaration on the Fortran side, because C does not pass on this information.
To turn c_p into an array on the Fortran side use:
call c_f_pointer( c_p, f_p, [3] )  ! [3] is the shape of the resulting Fortran array - fill in whatever is needed
I may be overlooking something - I have not tried it, but this is the principle :).
Arjen_Markus
GeoffH
Thank you Arjen_Markus. That's part of the solution. I hinted that this example is a very simplified form of my problem that illustrates the issue. That said, I do have the size of the array in the returned pointer array and I can extract that and return it in the foofunc (or more accurately for a Fortran user, foosub).
I still have some more work to do to get all the info back into the Fortran program, but you have broken my deadlock. Thanks.
GeoffH
