Fortran modules
franzw82
I wrote the following piece of code.
[bash]module module_1
   implicit none
   type :: mod_1_type
      integer(4) :: a = 10
   end type mod_1_type
   contains
   subroutine sub_mod1 (t1, t2)
     use module_2
     type (mod_1_type), intent(inout) :: t1
     type (mod_2_type), intent(inout) :: t2
     call sub_mod2 (t1, t2)
   end subroutine sub_mod1
end module module_1
module module_2
   implicit none
   type :: mod_2_type
      integer(4) :: a = 20
   end type mod_2_type
   contains
   subroutine sub_mod2 (t1, t2)
      use module_1
   end subroutine sub_mod2
end module module_2
program prog
   use module_1
   use module_2
   type (mod_1_type) :: t1
   type (mod_2_type) :: t2
   call sub_mod1 (t1, t2)
end program prog
[/bash]
I can't get the code to compile (Intel Visual Fortran Compiler XE 12.0.5.221). Any helpful comments would be appreciated.
GVautier
New Contributor III
hello
Your modules are nested. Module_1 refers to Module_2 and needs it to be compiled and Module_2 refers to Module_1 and also needs it to be compiled. So it cannot be compiled.
You can define your 2 types mod_1_type and mod_2_type in a new "module_type" for example and refer to it in module1 and module_2.
