29649 Discussions
Fortran shared lib .so shows undefined symbol error
csH2
Hi everyone I need help about a compilation issue.
I'm compiling a Fortran code to obtain shared library .so. In the code it uses a module. The compiling has no problem while it reports undefined symbol error when opening the .so library.
Code mesh_map.F are as follows:
#include "cfx5ext.h"
    dllexport(mesh_map)
          SUBROUTINE mesh_map (CZ, DZ, IZ, LZ, RZ)
          USE EXTRA_FLUID2
          USE ISO_C_BINDING
          USE IFPORT
          IMPLICIT NONE
          CHARACTER*(1) CZ(*)
          DOUBLE PRECISION DZ(*)
          INTEGER IZ(*)
          LOGICAL LZ(*)
          REAL RZ(*)
          MAP_STATUS = 1
          END
extra_fluid2.f90:
    Module EXTRA_FLUID2
    INTEGER :: map_status = 0
    end module EXTRA_FLUID2
Compiling command:
 ifort -c extra_fluid2.f90
/home/xxx/intel/oneapi/compiler/2021.4.0/linux/bin/intel64/ifort -fpic -assume 2underscore -check uninit -warn declarations -diag-error 6717 -ftz -O2 -fp-speculation=safe -fp-model=precise -fp-model=source -fimf-arch-consistency=true -qno-opt-dynamic-align -fpe0 -fomit-frame-pointer -real-size 32 -integer-size 32 -I/usr/ansys_inc/v192/CFX/include -o linux-amd64/ifort/mesh_map.o -c mesh_map.F
-lrt/xxx/intel/oneapi/compiler/2021.4.0/linux/bin/intel64/ifort -shared -o ./linux-amd64/ifort/libmesh_map.so linux-amd64/ifort/mesh_map.o extra_fluid2.o
When I check the .so library using:
ldd -r libmesh_map.so
The result shows as:
undefined symbol: extra_fluid2_mp_map_status__        (./libmesh_map.so)
How can I fix this? Thanks in advance.
I've tried compilation in Windows and no problem was found for the dll file. While in Linux it reports above error.
Steve_Lionel
When you compiled  mesh_map.F, you specified -assume 2underscore, but didn't specify that when compiling extra_fluid2.f90. This causes the global symbols to be inconsistent. Take that off.
I'm also puzzled by the "dllexport(meshmap)" in mesh_map.F. I have to assume that's a macro defined in the #include.
Steve_Lionel
csH2
Thank you Steve! Yes, I think dllexport should be removed.
Barbara_P_Intel
dllexport is not required for Linux.  Here's more info.
csH2
