Fortran traceback option
Gerdes_Gerhard_J
I run IFC 10.0.25 and 10.0.26. With both compilers the Fortran/run-time/traceback option does not work . I switched the the Fortran/Optimization/Omit Frame Pointers to "no" and the Linker/No/General/EnableIncremetalLinking also to "No(/INCREMENTAL:NO)", but this did not help. In the previous version I used, version 8 ,it worked perfectly.
Is there some more Option I have to consider?
Gerd
I tried a test in 10.0.027 and it worked ok for me. Please submit an issue to Intel Premier Support and attach a ZIP of a test project that shows the problem so that we can see exactly what you are trying.
