Function Overloading
brunocalado
How can I create a interface for overload this functions?
I need just to use
CALL func(a,b)
for the all functions
SUBROUTINE func1(a,b)
INTEGER :: a,b
END SUBROUTINE
SUBROUTINE func2(a,b)
REAL :: a,b
END SUBROUTINE
This is how it's done. Note that geneSize is not defined here, but I assume you'll take care of that.
[plain]MODULE test
USE IFPORT
INTERFACE getRandom
MODULE PROCEDURE getRandomA
MODULE PROCEDURE getRandomB
MODULE PROCEDURE getRandomC
END INTERFACE
CONTAINS
INTEGER FUNCTION getRandomA()
IMPLICIT NONE
getRandomA = MOD( IRAND(), geneSize-1 ) + 1 !        GENERATE RANDOM FROM 1 TO geneSize-1
END FUNCTION
INTEGER FUNCTION getRandomB(max)
IMPLICIT NONE
INTEGER, INTENT(IN) :: max
getRandomB = MOD( IRAND(), geneSize-1 ) + 1 !        GENERATE RANDOM FROM 1 TO geneSize-1
END FUNCTION
INTEGER FUNCTION getRandomC(min, max)
IMPLICIT NONE
INTEGER, INTENT(IN) :: min, max
getRandomC = MOD( IRAND(), geneSize-1 ) + 1 !        GENERATE RANDOM FROM 1 TO geneSize-1
END FUNCTION
END MODULE
[/plain]
Xiaoping_D_Intel
Quoting - brunocalado
I need just to use
CALL func(a,b)
INTEGER :: a,b
END SUBROUTINE
REAL :: a,b
END SUBROUTINE
You can use generic name for procedures like below:
INTERFACE func
INTEGER :: a,b
END SUBROUTINE
REAL :: a,b
END SUBROUTINE
END INTERFACE
brunocalado
Not working...
What's wrong?
INTERFACE getRandom
END FUNCTION
END FUNCTION
INTEGER FUNCTION getRandomC(min,max)
END FUNCTION
END INTERFACE
MODULE test
USE IFPORT
CONTAINS
IMPLICIT NONE
END FUNCTION
IMPLICIT NONE
END FUNCTION
IMPLICIT NONE
END FUNCTION
END MODULE
[plain]MODULE test
USE IFPORT
INTERFACE getRandom
END INTERFACE
CONTAINS
IMPLICIT NONE
END FUNCTION
IMPLICIT NONE
END FUNCTION
IMPLICIT NONE
END FUNCTION
END MODULE
[/plain]
brunocalado
[plain]MODULE test
USE IFPORT
INTERFACE getRandom
END INTERFACE
CONTAINS
IMPLICIT NONE
END FUNCTION
IMPLICIT NONE
END FUNCTION
IMPLICIT NONE
END FUNCTION
END MODULE
[/plain]
Worked.
Thank you.
