Function Pointer used in type
newrud
Hello I have a problem. I want to use a function pointer as a member in a type definition. The idea is to build a struct how its done in following code written in C:
#include
#include
typedef double Ptr(double *);
typedef struct
Ptr *func;
} MyStruct;
double lineareGleichung(double *x)
double slope;
slope = 2.0;
return slope*(*x);
int main(void)
double res, val;
int i;
MyStruct *ex = malloc(sizeof *ex);
if(ex != NULL)
ex->func = lineareGleichung;
for(i=0; i<5; i++)
val = i*0.5;
res = ex->func(&val);
printf("f(%lf) = %lf\\n", i*0.5, res);
free(ex);
return 0;
The following code, i wrote, is not working:
module test
implicit none
type functionPointer
contains
procedure(), pointer :: f
end type functionPointer
interface
subroutine f(x,y)
double precision :: x, y
end subroutine f
end interface
end module test
program functionPointerBsp
use test
implicit none
type(functionPointer):: FP
double precision :: x,y
integer :: i
FP%f => null()
FP%f => lineareGleichung
do i=1,5
x = i*0.5
call FP%f(x,y)
write(*,*) "F(",x,") = ", y
end do
contains
subroutine lineareGleichung(x,y)
double precision :: x, y, slope
slope = 2.d0
y = slope*x
end subroutine lineareGleichung
end program functionPointerBsp
The error is as follows:
error #8257: This is not a valid attribute for the type bound procedure definition statement. [POINTER]
module.f90(12): error #8262: The passed-object dummy argument must be dummy data object with the same declared type as the type being defined.
subroutine f(x,y)
Does anyone have an idea how to solve the problem?
You are very close.
The CONTAINS in the TYPE declaration is not what you want - this means that the things that follow are type-bound procedures. You simply want a procedure pointer component of the derived type. So initially, the CONTAINS is removed.
But then there is the following rule in the standard: "C453 If the procedure pointer component has an implicit interface or no arguments, NOPASS shall be specified." So after removing CONTAINS, replace the line that follows with this:
procedure(),nopass, pointer :: f
This works.
