29640 Discussions
Function return value not what is expected (F77)
Jonas_T_2
I am having a hard time understanding the behaviour of some FORTRAN 77 code.
The code:
      INTEGER*4 FUNCTION EINAUS(IY,IK)
      INTEGER*4 IRE
      IRE = 0
      EINAUS = IRE
      END FUNCTION
      SUBROUTINE STDAUS
      INTEGER*4 IRE
      IRE = 1
      WRITE(*,*) 'IRE= ',IRE
      WRITE(*,*) 'EINAUS(1,3)= ',EINAUS(1,3)
      IRE = EINAUS(1,3)
      RETURN
      END
The output:
 IRE=            1
 EINAUS(1,3)=             NaN
 IRE=  -2147483648
I would have expected the last two lines to read 0 instead of NaN or 0x80000000.
Please point me to the obvious thing I am missing here.
andrew_4619
Try the code below. It is however much better to have your functions in a module rather than external.
      SUBROUTINE STDAUS
      INTEGER*4 IRE
      integer(4), external :: EINAUS ! declare the function
      IRE = 1
      IRE = EINAUS(1,3)
      RETURN
      END
andrew_4619
      SUBROUTINE STDAUS
      INTEGER*4 IRE
      IRE = 1
      IRE = EINAUS(1,3)
      RETURN
      END
Jonas_T_2
Thank you very much. That's it.
I keep all code, that I added, in modules. But since it is not mine, and I just had to make some adjustments (procedure to function) I'll add it in like that. I'll try to convince him, since it would reduce that huge amount of COMMON blocks aswell.
