29647 Discussions
Function returning POINTER as actual argument?
Thomas_F_1
I am having problems with ifort (15.0.0.077) when a function returning a pointer is an actual argument to a function with a pointer dummy argument. If I use a temporary pointer variable, the function call works as expected. But if I place the function call directly as the actual argument, I get random crashes and/or garbage when I run the compiled code. I've created a simple example that demonstrates the problem. I don't see anything in Metcalf, Reid, and Cohen that suggests this isn't allowed. Certainly the compiler doesn't complain about it.
module m
    type int
        integer :: i = 0
    end type
    class(int), pointer :: mptr => NULL()
contains
    subroutine SetPtr(ptr)
        class(int), pointer, intent(in) :: ptr
        mptr => ptr
    end subroutine
    function GetPtr()
        class(int), pointer :: GetPtr
        GetPtr => mptr
    end function
    subroutine PrintPtr(ptr)
        if (associated(ptr)) then
            print "('Val: ',i0)", ptr%i
        else
            print "(a)", "Null pointer"
        endif
    end subroutine
end module m
program test
call run
end program
subroutine run
use m
implicit none
    class(int), pointer :: value
    class(int), pointer :: ptr
    nullify(ptr)
    allocate(value)
    value%i = 23
    call SetPtr(value)
    call PrintPtr(value)     ! Prints "Val: 23"
    call PrintPtr(ptr)       ! Prints "Null pointer"
    ptr => GetPtr()
    call PrintPtr(ptr)       ! Prints "Val: 23"
    call PrintPtr(GetPtr())  ! Prints "Val: <random garbage>"
    deallocate(value)
    return
end subroutine
Thanks, we'll take a look.
