Function with character argument
pwalkergeoalgorithms
I am trying to recompile some legacy FORTRAN developed on a PC in the 90-s. The program aborts at the return statement when the following function is called (all the other code was commented out):
subroutine WrtHdr(lu,message)
implicit none
integer lu
character*(*) message
return
end
The call is:
character*100 temp_string
integer i_out
i_out = 6
temp_string = 'NEW SECTION'
call WrtHdr(i_out,temp_string)
What could be the problem with this code? Thanks.
Kevin_D_Intel
There's more at play here. The small snippet compiles/runs fine.
Can you tell us what compiler version (-V) and compiler options were used and showthe actual abort error message?
jimdempseyatthecove
Try changing " end" to "end subroutine" (note left adjust of text)
Jim
Jim
I did this, but nothing seemed to change. I think it is a debugger issue. Please see my other reply. - Thanks PW
I managed to get the code working by cloning the function, renaming it, calling the cloned function. In the process I deleted all the blank spaces in the code and replaced the deleted blanks with spaces. - Could the debugger be sensitive to spurious characters in the code?
The code executed after I did this. I noticed that when I step into the code with gdb, then execution fails when I step into the function. If I step over the function, then the program terminates properly. -
The failure occurs when a breakpoint is set atWrtSectionHdrand I step into the function, and then step intoWrtMessageXas follows:
Console output:
This GDB was configured as "x86_64-apple-darwin".tty /dev/ttys030
Loading program into debugger
sharedlibrary apply-load-rules all
Program loaded.
run
[Switching to process 11466]
Running
Starting test
Data Formatters temporarily unavailable, will re-try after a 'continue'. (Attempt to take address of value not located in memory.)
Current language: auto; currently fortran
The Debugger has exited due to signal 11 (SIGSEGV).The Debugger has exited due to signal 11 (SIGSEGV).
(gdb)
------- In this case the execution stopped at WriteMessageX in WriteSectionHdr - the code is below:
program test
implicit none
integer i_out
write(6,*) "Starting test"
i_out = 6
c call WrtNewHdr(i_out,temp_string) ! I cloned the code and ran the cloned code here
call WrtSectionHdr(i_out,temp_string)
write(6,*) "Ending test"
end
subroutine WrtSectionHdr(lu,message)
implicit none
integer lu
call WrtMessageX(lu,message) ! exits here with code 11
return
end subroutine
subroutine WrtMessageX(lu,message) ! I clonedWrtMessage for testing
C Write a message to the logical unit lu
implicit none
integer lu
character*512 message
integer iend
write(lu,*) message
return
c iend = index(message,char(26))
c if (lu.ne.0) then
c if (iend.eq.0) then
c write(lu,*) message
c else
c write(lu,*) message(1:iend)
c end if
c end if
c
c return
end subroutine
However, the execution ends normally when I step across the function at the break point:
This GDB was configured as "x86_64-apple-darwin".tty /dev/ttys032
Program loaded.
run
[Switching to process 11488]
Running
Starting test
NEW SECTION
Ending test
I did not set up a rule for compiling the include files, assuming this is not important because they are called from the fortran. the linker complains, for example
[WARN]warning: no rule to process file '$(PROJECT_DIR)/NUMBERS.INC' of type sourcecode.pascal for architecture i386
....... I could not find the text output that lists the compiler settings used in the build results window, but any ideas about what might be happening would be appreciated - Thanks. PW
